    thermistor error 2000 degree
    259
    • piatraundefined
      piatra
      Hello and many thanks in advance for your help
      My ex nozzle thermistor was down and I have replaced it with a new one and now I get 2000 degree fault at its reading
      I am running duet 3.4.1 firmare
      Please advice and thanks
      piatraundefined infiniteloopundefined deckingmanundefined 3 Replies Last reply Reply Quote 0
      • piatraundefined
        piatra @piatra
        @piatra said in thermistor error 2000 degree:
        pS: and I have just replaced the thermistor, nothing else
        • infiniteloopundefined
          infiniteloop @piatra
          @piatra
          You have a decent short somewhere between the Duet and thermistor. Check your lines.
          • piatraundefined
            piatra
            I have double checked, hardly to be a short
            Now I am trying to figure it out if error is related with the reason that i had a pt100 before and now I have a ordinary one (not sure even the resistance. In my config.g is set for senzor pt100…
            M308 S1 P"spi.cs1" Y"rtd-max31865" ; create sensor number 1 as a PT100 sensor in the first position on the Duet 2 daughter board connector
            • deckingmanundefined
              deckingman @piatra
              @piatra To expand on what @infiniteloop has said, the thermistors that we use in our printers are NTC = Negative Temperature Coefficient. Which means that as the temperature increases, the resistance decreases. So if you are seeing a very high temperature (2000) deg C, then it means that the resistance is very low = a short circuit. It's possible that the thermistor itself is faulty but the usual cause is a wiring fault. If you have a multimeter, then you could check the resistance which, for a "normal" thermistor should be 100KOhms @25 deg C.
              • piatraundefined
                piatra
                Thanks, but if I am buying any sensor, but not pt100 and the measurements are good should I live the config file as it is? With pt100?
                infiniteloopundefined 1 Reply Last reply Reply Quote 0
                  deckingman @piatra
                  You need to change that M308 line https://docs.duet3d.com/User_manual/Reference/Gcodes#m308-set-or-report-sensor-parameters
                  Also, you can't connect a thermistor to a PT100 daughter board.
                  Edit. This might help too https://docs.duet3d.com/en/User_manual/Connecting_hardware/Temperature_connecting_thermistors_PT1000
                    @piatra To expand on what @deckingman has said, you need to connect the thermistor to E0_TEMP or E1_TEMP as described here. Further reading: Configuring RepRapFirmware…
                    • piatraundefined
                      piatra
                      Now it is clear. Many thanks all. First step is to find out what thermistor is or buy one with specs
                      Thanks a lot folks
                        Measured at room temperature, you should see a resistance of several kOhm up to 100 kOhm. Round that, and you have your T parameter for M308. Good luck!
                        • piatraundefined
                          piatra
                          Thanks for the tip
