    d36hc - Configure more temp-sensors?
    Using Duet Controllers
    • pro3dundefined
      pro3d
      So I already have 4 temp sensors attached to the board and need more but the board only has 4 pins for this. Can I configure some other IO to do the job and if so how? Talking about the drybox for the valkyrie
      Valkyrie DIY High Temp 3D Printer
      R&D - Engineering Designer - Viking 3D Printers
      https://vkingprinter.com/
      • gloomyandyundefined
        gloomyandy @pro3d
        @pro3d If you can't add another thermistor, how about using a DHT sensor the humidity function might come in handy? https://docs.duet3d.com/en/User_manual/Connecting_hardware/Temperature_connecting_DHT
        pro3dundefined 1 Reply Last reply Reply Quote 0
        • pro3dundefined
          pro3d @gloomyandy
          @gloomyandy said in d36hc - Configure more temp-sensors?:
          Can I use that for controlling temperature with a heater? WE already have a temp and humidity sensor bu can I use those to control the heater?
          gloomyandyundefined dc42undefined 2 Replies Last reply Reply Quote 0
            gloomyandy @pro3d
            @pro3d Yep should be no problem. I use one to control one of the fans on my toolchanger.
              dc42 administrators @pro3d
              @pro3d you can also use PT100 or thermocouple daughter boards, or CAN-connected expansion boards to connect additional temperature sensors.
