How do I interpret the fan wiring for 1LC?
I'm used to the duet 2 where everything has a GND. Hope do I hook up 2 wire fans to the toolboard? I assume the pins should be the only two commonly named pins between out1 and out2, since they both support two wire fans, but out1 has no GND.
This post is deleted! -
@herve_smith I meant out2 didn't have a GND pin.
I couldn't find where this was documented, would you happen to have a link?
I don't know what you mean by "switch" is that fan normally always on?
@gnydick you wire between out2 and +vout.
The fan and heater ports switch on the ground side -
@jay_s_uk yeah, I figured that given a 2 pin fan doesn't have a tach. I was just correcting my statement.
