    M92 and scaling problems
    Gcode meta commands
    • ObiWan2Printundefined
      ObiWan2Print
      So I fixed all my bed leveling problems and got the Railcore 2 to print with a Mosquito Magnum extruder. Now I have a scaling problem. When I print a 20mm cube from thingaverse it ends up being a 40mm cube. I tried halving the values in the config file for M92 X, Y and Z and it printed the cube at 20mm but my print bed size is also half what it used to be. How do I fix this problem of scaling?
      Rushmere3Dundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • Rushmere3Dundefined
        Rushmere3D @ObiWan2Print
        @obiwan2print post your config. Using the code formatting feature (</>)
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
          Phaedrux Moderator @ObiWan2Print
          @obiwan2print said in M92 and scaling problems:
          Double the values in M208? They should be the actual physical MM values though.
