    Swapping 0 location
    • Tryptamineundefined
      Tryptamine
      I somehow calibrated my printer s.t. The 0 location is rear right.
      I want to be it at the front left.
      I try to switch the configuration but I do not get it to work.
      The old, working stuff is:
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S0                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2:4 E3                                   ; set drive mapping
      M92 X160.00 Y160.00 Z400.00 E420.00                ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E1200.00               ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z1000.00 E18000.00          ; set maximum speeds (mm/min)
      M201 X1200.00 Y1200.00 Z20.00 E2000.00             ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z800 E1000 I30                    ; set motor currents (mA) and motor idle factor in per cent
      M208 X345 Y305 Z290 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T12000               ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X28 Y9 Z1                                 ; set Z probe trigger value, offset and trigger height
      M557 X70:370 Y15:314 P4                           ; define mesh grid
      M308 S0 P"e1temp" Y"thermistor" T105526 B4138      ; configure sensor 0 as thermistor on pin e1temp (bedtemp BROKEN)
      ;M307 H1 A1123.6 C133.0 D3.5 S0.40 V23.9 B0
      M307 H1 R10.976 K0.652:0.000 D2.65 E1.35 S0.10 B0 V24.0
      M308 S1 P"e0temp" Y"thermistor" T103901 B4138      ; configure sensor 1 as thermistor on pin e0temp
      ;M301 H0 P131.9 I1.423 D566.0
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T120                                 ; set fan 1 value. Thermostatic control is turned on
      I generated a new RepRap config with endstops located at the axis minima:
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M203 X18000.00 Y18000.00 Z180.00 E1200.00          ; set maximum speeds (mm/min)
      M574 X1 S1 P"xstop"                                ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M558 P9 C"^zprobe.in" H3 F180 T18000               ; set Z probe type to bltouch and the dive height + speeds
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      And now when homing, axis are moving in the wrong directions. So they are going where there is no endstop.
      Do i additionally have to invert my Motors?
      My endstops are on the front left side of my printer.
      Here should also be the origin, X pointing to the right, y to the back, and z upwards, generating a right-handed coordinate system.
        dc42 administrators @Tryptamine
        @tryptamine yes you will need to invert the X and Y motor directions, which you can do with the M569 commands - change S1 to S0 for those two motors.
