Is the Configuration file on the SD drive
If I replace my Duet 2 WiFi, is the configuration file for the printer on the SD card?
I have mysteriously lost comms with my existing board, and I didn't do the config.
Any help appreciated on how to migrate onto a new board? Thanks
@jp5 yes it is. But you're best off following https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
@jay_s_uk Thanks.
I tried that but I don't see a DIAG LED lit - so no 5V? I have the green 3.3V though.
BL touch deploys, bed heater turns on automatically.
New Duet2?
@jp5 the diag light is separate to the 5v LED. If the 3.3v is lit then you should have 5v as it's powered from that.
Have you tried erasing the firmware and using bossa? Does anything get hot when powered from 24v? -
@jp5 said in Is the Configuration file on the SD drive:
Does that still happen when the SD card is removed?
Does the SD card still show it's contents in a computer?
