    Only probe where the part will be printed
    51
    3.8k
    • RatRig0331undefined
      RatRig0331
      I know this was brought up a few times and I’m finding it hard to follow the timeline from 2020 for mesh probing only where the part will be printed I’m using a rat rig v-500 with prusa slicer. I read it can be done and I’ve tryed following the chat instructions but have had no luck and was hoping someone would be willing to hold my hand on this one to get the bed mesh only probing where the part will be printing.
      • OwenDundefined
        OwenD
        Here's how I do it.
        I'm sure there's may other ways.
        EDIT: I added my heating calls in superslicer because I realised I turn the heaters off in the probing, so you must heat after.
        In config.g I call this macro to set my initial probe points
        I also do this any other time I want to reset them to the full bed size.
        M98 P"0:/sys/setDefaultProbePoints.g" ; define default mesh grid
        ;0:/sys/setDefaultProbePoints.g
        var SafeZone = 10
        var MinReachableX = (sensors.probes[0].offsets[0] + var.SafeZone)
        var MaxReachabeX = (move.axes[0].max - sensors.probes[0].offsets[0] - var.SafeZone)
        var MinReachableY =  (sensors.probes[0].offsets[1] + var.SafeZone)
        var MaxReachabeY = (move.axes[1].max - sensors.probes[0].offsets[1] - var.SafeZone)
        M557 X{var.MinReachableX,var.MaxReachabeX} Y{var.MinReachableY,var.MaxReachabeY} S30; define mesh grid
        if !exists(global.minProbeX)
        	global minProbeX = move.compensation.probeGrid.mins[0]
        else
        	set global.minProbeX = move.compensation.probeGrid.mins[0]
        if !exists(global.minProbeY)
        	global minProbeY = move.compensation.probeGrid.mins[1]
        else
        	set global.minProbeY = move.compensation.probeGrid.mins[1]
        if !exists(global.maxProbeX)
        	global maxProbeX = move.compensation.probeGrid.maxs[0]
        else
        	set global.maxProbeX = move.compensation.probeGrid.maxs[0]
        if !exists(global.maxProbeY)
        	global maxProbeY = move.compensation.probeGrid.maxs[1]
        else
        	set global.maxProbeX = move.compensation.probeGrid.maxs[1]
        In Prusa/Superslicer I have
        set global.minProbeX = {first_layer_print_min[0]}
        set global.maxProbeX = {first_layer_print_max[0]}
        set global.minProbeY = {first_layer_print_min[1]}
        set global.maxProbeY = {first_layer_print_max[1]}
        T[current_extruder] ; select tool
        M568 P[current_extruder] R{"{heat.coldExtrudeTemperature+5}"} S[first_layer_temperature_0] A1 ; (set extruder to stanby to soften any protruding filament before probing )
        M106 P[current_extruder] S0 ;Start with fan off
        M118 S"Heating Bed"
        G4 S1
        M140 S[first_layer_bed_temperature_0]  R{bed_temperature[0]-20}; Set fast bed temp & standby - Standby is 20 degrees less than normal.
        M116 ; Wait for bed before doing mesh probe.
        G29 ; do mesh for printed area
        G29 S1  ; load small mesh
        M568 P[current_extruder] R{"{heat.coldExtrudeTemperature+5}"} S[first_layer_temperature_0] A2 ; (set standby and active temperatures for active tool.  Standby is 5 degrees above cold extrude temp )
        M116 ; wait for temps
        In mesh.g I have
        ;0:/sys/mesh.g
        ; run when G29 with no paramters is called.
        ; if this file not found G29 S0 will run
        var m557MinX = 40;  ; put your default here
        var m557MaxX = 180;  ; put your default here
        var m557MinY = 20;  ; put your default here
        var m557MaxY = 180;  ; put your default here
        var MinSpace = 10 ; put default minimum spacing
        var MaxSpace = 30 ; put default maximum spacing
        var ProbeNumX = 8 ; put default probe points
        var ProbeNumY = 8 ; put default probe points.
        var ProbeCenterX = 90 ; will be updated to probe centre of print
        var ProbeCenterY = 90 ; will be updated to probe centre of print
        var MaxProbePoints = max(floor(move.axes[0].max / var.MaxSpace),floor(move.axes[1].max / var.MaxSpace)) ; maximum points in either axis
        echo "Maximum allowed probe points is " ^ var.MaxProbePoints ^ " using max space of " ^ var.MaxSpace
        var SafeZone = 3 ; safety margin for probing near edge.
        if exists(global.minProbeX)
        	if global.minProbeX < (sensors.probes[0].offsets[0] + var.SafeZone)
        		echo "minProbeX (" ^ global.minProbeX ^ ") unreachable - reset to " ^ (sensors.probes[0].offsets[0] + var.SafeZone)
        		set global.minProbeX = (sensors.probes[0].offsets[0] + var.SafeZone)
        	set var.m557MinX = global.minProbeX
        if exists(global.maxProbeX)
        	if global.maxProbeX < (global.minProbeX + (var.MinSpace*2))
        		set global.maxProbeX = (global.minProbeX + (var.MinSpace*2))
        	if global.maxProbeX > (move.axes[0].max - sensors.probes[0].offsets[0] - var.SafeZone)
        		echo "maxProbeX (" ^ global.maxProbeX ^ ") unreachable - reset to " ^ (move.axes[0].max - sensors.probes[0].offsets[0] - var.SafeZone)
        		set global.maxProbeX = (move.axes[0].max - sensors.probes[0].offsets[0] - var.SafeZone)
        	set var.m557MaxX = global.maxProbeX
        if exists(global.minProbeY)
        	if global.minProbeY < (sensors.probes[0].offsets[1] + var.SafeZone)
        		echo "minProbeY (" ^ global.minProbeY ^ ") unreachable - reset to " ^ (sensors.probes[0].offsets[1] + var.SafeZone)
        		set global.minProbeY = (sensors.probes[0].offsets[1] + var.SafeZone)
        	set var.m557MinY = global.minProbeY
        if exists(global.maxProbeY)
        	if global.maxProbeY < (global.minProbeY + (var.MinSpace*2))
        		set global.maxProbeY = (global.minProbeY + (var.MinSpace*2))
        	if global.maxProbeY > (move.axes[1].max - sensors.probes[0].offsets[1] - var.SafeZone)
        		echo "maxProbeY (" ^ global.maxProbeY ^ ") unreachable - reset to " ^ (move.axes[1].max - sensors.probes[0].offsets[1] - var.SafeZone)
        		set global.maxProbeY = (move.axes[1].max - sensors.probes[0].offsets[1] - var.SafeZone)
        	set var.m557MaxY = global.maxProbeY
        echo "Probing grid - X" ^ var.m557MinX ^ ":" ^ var.m557MaxX ^ " Y" ^ var.m557MinY ^ ":" ^ var.m557MaxY
        var MinProbesX = floor((var.m557MaxX - var.m557MinX) / var.MaxSpace)
        ;echo "Min Probes X is " ^ var.MinProbesX
        var MaxProbesX = floor((var.m557MaxX - var.m557MinX) / var.MinSpace)
        ;echo "Max Probes X is " ^ var.MaxProbesX
        set var.ProbeNumX = min(var.MaxProbePoints,var.MaxProbesX)
        var MinProbesY = floor((var.m557MaxY - var.m557MinY) / var.MaxSpace)
        ;echo "Min Probes Y is " ^ var.MinProbesY
        var MaxProbesY = floor((var.m557MaxY - var.m557MinY) / var.MinSpace)
        ;echo "Max Probes Y is " ^ var.MaxProbesY
        set var.ProbeNumY = min(var.MaxProbePoints,var.MaxProbesY)
        ; sanity check probe points
        if var.ProbeNumX<2
        	set var.ProbeNumX=2
        if var.ProbeNumY<2
        	set var.ProbeNumY=2
        if var.ProbeNumX > var.MaxProbePoints
        	set var.ProbeNumX = var.MaxProbePoints
        if var.ProbeNumY > var.MaxProbePoints
        	set var.ProbeNumY = var.MaxProbePoints
        if (var.ProbeNumX * var.ProbeNumY) > 441
        	if var.ProbeNumX > 21
        		set var.ProbeNumX = 21
        		echo "Too many X points - reduced to 21"
        	if var.ProbeNumY > 21
        		set var.ProbeNumY = 21
        		echo "Too many Y points - reduced to 21"
        echo "Probing " ^ var.ProbeNumX ^ " points in X direction & " ^ var.ProbeNumY ^ " points in Y direction"
        ;check state of heaters
        var bedState = heat.heaters[0].state
        var bedActiveTemp = heat.heaters[0].active
        var bedStandbyTemp = heat.heaters[0].standby
        var nozzleState = heat.heaters[1].state
        M140 P0 S-276 ; turn off bed heater
        M568 P0 A0 ; turn off nozzle heater
        ; do probing
        set var.ProbeCenterX = (global.maxProbeX - ((global.maxProbeX - global.minProbeX)/2)) ; calculate centre point of probe area
        set var.ProbeCenterY = (global.maxProbeY - ((global.maxProbeY - global.minProbeY)/2)) ; calculate centre point of probe area
        echo "Setting Z datum point at X" ^ var.ProbeCenterX ^ " Y" ^ var.ProbeCenterY
        ; set Z = 0 to centre of probe area
        G1 X{var.ProbeCenterX- sensors.probes[0].offsets[0]} Y{var.ProbeCenterY- sensors.probes[0].offsets[1]} Z{sensors.probes[0].diveHeight+2} F3600
        G30
        echo "Mesh probing"
        M557 X{var.m557MinX,var.m557MaxX} Y{var.m557MinY,var.m557MaxY} P{var.ProbeNumX,var.ProbeNumY}
        if result != 0
        	abort "ERROR: could not create mesh"
        else
        	G29 S0
        	if result != 0
        		abort "ERROR: Mesh probing failed"
        	else
        		echo "Mesh probing successful.   Loading mesh.."
        echo "Reset Z datum in mesh centre"
        G30
        ; turn the heaters back on if needed
        if var.bedState != "off"
        	M140 S{var.bedActiveTemp} R{var.bedStandbyTemp}
        	if var.bedState="active"
        		M144 P0 S1 ; put bed on active temp
        	else
        		M144 P0 S0 ; put bed on standby temp
        if var.nozzleState	!= "off"
        	if var.nozzleState = "active"
        		M568 P0 A2 ; set nozzle to active
        	else
        		M568 P0 A1 ; set nozzle to standby
        RatRig0331undefined dc42undefined 3 Replies Last reply Reply Quote 2
          RatRig0331 @OwenD
          @owend how do you call that macro in your main config.g, and where in prusa slicer do you add the other macro?
            RatRig0331 @OwenD
            @owend I think I figured it out but I’m getting a error massage: unknown variable ‘global.minprobex’
            OwenDundefined 1 Reply Last reply Reply Quote 0
            • OwenDundefined
              OwenD @RatRig0331
              @ratrig0331
              You need to put this line in config.g in place of your normal M557
              Then set all your default probe settings in the areas at the start of the macro.
              In superslicer put all the code provided in your start gcode
                dc42 administrators @OwenD
                @owend said in Only probe where the part will be printed:
                You appear to be using a mixture of { } and [ ] to surround named values that you want PrusaSlicer to substitute for. Which is correct?
                • OwenDundefined
                  OwenD @dc42
                  The square brackets are legacy place holders, so should probably be replaced by curly brackets.
                  I just tried changing them all to curly brackets.
                  However in Superslicer at least, [first_layer_temperature_0] only seems to work with a square bracket.
                  EDIT
                  It seems things like [first_layer_temperature_0] have been replaced by {first_layer_temperature[0]}
                  I've revised the start Gcode related to probing to this (there are of course other commands need in the start code)
                  T{current_extruder} ; select tool 1
                  M568 P{current_extruder} R{"{heat.coldExtrudeTemperature+5}"} S{first_layer_temperature[current_extruder]} A1 ; (set extruder to stanby to soften any protruding filament before probing )
                  M106 P{current_extruder} S0 ;Start with fan off
                  M140 S{first_layer_bed_temperature[current_extruder]}  R{bed_temperature[0]-20}; Set fast bed temp & standby - Standby is 20 degrees less than normal.
                  G01 X0 Y{"{move.axes{1}.max}"} Z0.6  F1500 ; Move to back corner while heating
                  M568 P{current_extruder} R{"{heat.coldExtrudeTemperature+5}"} S{first_layer_temperature[current_extruder]} A2 ; (set standby and active temperatures for active tool.  Standby is 5 degrees above cold extrude temp )
                  M116 ; Wait for all temps to stabilise
                  RatRig0331undefined 1 Reply Last reply Reply Quote 0
                    RatRig0331 @OwenD
                    @owend when I restart I get this
                    Error: (sensors.probes[0].offsets[0] + var.SafeZone)array index out of bounds of setDefaultProbePoints.g
                    And if I try to start a print I get this
                    Error: unknown variable 'global.minProbeX'
                    dc42undefined OwenDundefined 2 Replies Last reply Reply Quote 0
                      dc42 administrators @RatRig0331
                      @ratrig0331 have you opened the GCode file in a text editor, to see what the slicer has actually generated?
                      RatRig0331undefined 2 Replies Last reply Reply Quote 0
                        RatRig0331 @dc42
                        @dc42 not yet I’ll take a look
                          RatRig0331 @dc42
                          @dc42 it looks like its all there in the gcode
                          ; external perimeters extrusion width = 0.40mm
                          ; perimeters extrusion width = 0.40mm
                          ; infill extrusion width = 0.40mm
                          ; solid infill extrusion width = 0.40mm
                          ; top infill extrusion width = 0.40mm
                          ; first layer extrusion width = 0.45mm
                          M73 P0 R8
                          M107
                          M104 S205 ; set temperature
                          ;TYPE:Custom
                          set global.minProbeX = 183.982
                          set global.maxProbeX = 316.018
                          set global.minProbeY = 188.982
                          set global.maxProbeY = 311.018
                          T0 ; select tool 1
                          M568 P0 R{heat.coldExtrudeTemperature+5} S205 A1 ; (set extruder to stanby to soften any protruding filament before probing )
                          M106 P0 S0 ;Start with fan off
                          M140 S68 R45; Set fast bed temp & standby - Standby is 20 degrees less than normal.
                          G01 X0 Y{move.axes{1}.max} Z0.6 F1500 ; Move to back corner while heating
                          M568 P0 R{heat.coldExtrudeTemperature+5} S205 A2 ; (set standby and active temperatures for active tool. Standby is 5 degrees above cold extrude temp )
                          M109 S205 ; set temperature and wait for it to be reached
                          G21 ; set units to millimeters
                          G90 ; use absolute coordinates
                          M83 ; use relative distances for extrusion
                          ; Filament gcode
                          SET_GCODE_OFFSET Z=0
                          SET_PRESSURE_ADVANCE ADVANCE=0.05
                          M107
                          ;LAYER_CHANGE
                          ;Z:0.2
                          ;HEIGHT:0.2
                          ;BEFORE_LAYER_CHANGE
                          ;0.2
                          G92 E0
                          this is what i changed in the mesh.g for my 500x500mm xycore
                          ;0:/sys/mesh.g
                          var m557MinX = 25; ; put your default here
                          var m557MaxX = 450; ; put your default here
                          var m557MinY = 25; ; put your default here
                          var m557MaxY = 450; ; put your default here
                          var ProbeCenterX = 285 ; will be updated to probe centre of print
                          var ProbeCenterY = 270 ; will be updated to probe centre of print
                          • OwenDundefined
                            OwenD @RatRig0331
                            @ratrig0331
                            Sounds like it's not finding a sensors.probe[0] when you run the initial setup from config.g
                            As that line is at the start of the macro, it never gets to the lines that set the global variables up.
                            Make sure your probe is configured before calling the macro.
                            Maybe post you config.g so we can see how your probe(s) are configured
                            RatRig0331undefined 3 Replies Last reply Reply Quote 0
                              RatRig0331 @OwenD
                              @owend
                              ;;; BLTouch ;;;
                              M950 S0 C"io2.out" ; Create a servo pin on io2
                              M558 P9 C"io2.in" H5 F240 T10800 A5 ; set Z probe type to unmodulated and the dive height + speeds
                              G31 P25 X-29.00 Y-2.00 Z2.471
                                RatRig0331 @OwenD
                                @owend
                                ;;; Endstops ;;;
                                M574 X1 S1 P"io1.in" ; configure active high endstops
                                M574 Y2 S1 P"io0.in" ; configure active high endstops
                                M574 Z1 S2
                                • OwenDundefined
                                  OwenD @RatRig0331
                                  @ratrig0331
                                  Make sure
                                  Comes after your G31 in your BlTouch section
                                    RatRig0331 @OwenD
                                    @owend ok I’ll move it and give it a shot
                                      RatRig0331 @OwenD
                                      @owend that did the trick but now i need to turn down the amount of probe points
                                      with my 100x100mm print its trying to do a 13x13 grid what do i tweak to lower that?
                                        RatRig0331 @OwenD
                                        @owend ok after letting it 100% there were more errors
                                        8/14/2022, 10:15:03 PM Error: M557: bad grid definition: Spacing too small
                                        8/14/2022, 10:14:19 PM Error: in GCode file line 773: G1: expected '}'
                                        line 773 is your
                                        • OwenDundefined
                                          OwenD @RatRig0331
                                          @ratrig0331
                                          Change your minSpace and maxSpace in the macro to reduce number of probe points
                                          Try 50 & 100
                                          The G1 is my bad
                                          I did a search and replace when I was changing the braces, but changed one that should remain a square bracket
                                          Change this line in superslicer
                                          To
                                          G01 X0 Y{"{move.axes[1].max}"} Z0.6 F1500 ; Move to back corner while heating
                                          Or delete the line if you don't want to move there while heating
                                            RatRig0331 @OwenD
                                            @owend
                                            One down one to go I’m still getting the m557 error with the 50/100 spacing will this be normal a normal error from down sizing the bed mesh or is there a fix
                                            ——-Error: in GCode file line 773: G1: expected '}'———- is now fixed
