    how to turn off all fans at the end of print
    Gcode meta commands
    3.0k
    • RatRig0331undefined
      RatRig0331
      these are my fan configs in config.g
      ;;; Fans ;;;
      M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
      M106 P0 C"Hotend Fan" S255 H1 T45 ; set fan 0 name and value. Thermostatic control turned on for Hotend
      M950 F3 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
      M106 P3 C"RSCS Towers" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off
      M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
      M106 P2 C"MCU Fan" S5 H1 T45 ; set fan 2 name and value. Thermostatic control turned on for extruder
      M950 F1 C"out6" Q6000 ; create fan 2 on pin out6 and set its frequency
      ;M42 P1 S0.5 ;set 50% of mas speed
      M106 P1 C"CPAP" S0 H-1 X0.5 ; set fan 2 name and value. Thermostatic control turned on for CHAMBER
      this is my end of print slicer gcode
      M104 S0; (TURN OFF HOTEND)
      M140 S0; (TURN OFF BED)
      M106 S0; (TURN OFF PART FAN)
      G91;
      G1 E-10. F300;
      G1 Z2.5 E-5;
      G1 Z17.5 F2000;
      G28X50Y50 ;(HOME X&Y)
      i want to know what do i need to add to the slicer end gcode to turn on and off my:
      • chrishammundefined
        chrishamm administrators @RatRig0331
        @ratrig0331 You can use the M106 P parameter to specify the fan index to control. So to turn off fan #3 (M950 F3), use M106 P3 S0.
        Duet software engineer
        RatRig0331undefined 1 Reply Last reply Reply Quote 0
          RatRig0331 @chrishamm
          @chrishamm what is I wanted to tell it to turn on at a certain layer height? Is that possible?
          Norderundefined deckingmanundefined 3 Replies Last reply Reply Quote 0
          • Norderundefined
            Norder @RatRig0331
            @ratrig0331
            You can usually set this in the slicer from which layer height the fan should start.
            For example in PrusaSlicer...
            Sorry, German layout, but you will find it on you if you use PrusaSlicer.
            Other slicers also have this setting.
            DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
            Thingiverse
            Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
            • Rushmere3Dundefined
              Rushmere3D @Norder
              @norder That's to control the part cooling fan, not a specific fan.
              Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
              Norderundefined 1 Reply Last reply Reply Quote 0
              • deckingmanundefined
                deckingman @RatRig0331
                @ratrig0331 said in how to turn off all fans at the end of print:
                You'll have to do via the slicer or by editing the gcode file or possibly by using conditional gcode and probably daemon.g. The latter is complicated. If the fan is used as a part cooling fan, then the easiest way is to map that fan to a tool e.g. M563 P0 F3 would map fan 3 to tool 0 then any M106 command in the gcode file will set the speed for fan 3. If the fan is something other than a part cooling fan, then the next easiest way is to open up the gcode file in a text editor such as notepad++, locate the layer that you want the fan to come on at, then add the command M106 P3 Snn (where nn is the speed you want it to run at (0 to 255)).
                • Norderundefined
                  Norder @Rushmere3D
                  @rushmere3d said in how to turn off all fans at the end of print:
                  Oh that's the point.
                  I translate the page with Google Translate, and sometimes a page is translated so strangely that you almost have to guess what is meant.
                  I thought it was the component fan. 😉
                  Thingiverse
                  • Norderundefined
                    Norder @RatRig0331
                    Inserting a GCode from a specific layer is easy with PrusaSlicer.
                    Here's an example...
                    I don't know which slicer you use, but maybe it will help you ?
                    Google Translate
                    --- Original Text ---
                    Das einfügen eines GCode ab einem bestimmten Layer ist mit dem PrusaSlicer ganz einfach.
                    Hier ein Beispiel...
                    (Siehe Screenshots)
                    Ich weiß zwar nicht welchen Slicer Du nutzt, aber vielleicht hilft es Dir weiter ?
                    Thingiverse
                    RatRig0331undefined 1 Reply Last reply Reply Quote 2
                      RatRig0331 @Norder
                      @norder no that helps thanks I use both super slicer and prusa slicer depending on my needs. The reason for the question is some Prints like pla use cooling and some times need additional cooling so I turn on the towers, but if I run the print over night since I turn them on from the duet control it will run the fans all night until I turn them off in the morning even though the print took a hour ect…
                      Just one other question is there a timer macro that could be used at the end so when the print finishes run the fan for 5 minutes than turn off?
                      Norderundefined 2 Replies Last reply Reply Quote 0
                      • Norderundefined
                        Norder @RatRig0331
                        @ratrig0331
                        With the G4 command you can specify a pause that will wait until the next command is processed by the GCode.
                        HERE the link to the GCode explanation.
                        Thingiverse
                        • Norderundefined
                          Norder @RatRig0331
                          @ratrig0331
                          You could create another printer profile by inserting this waiting time in the end GCode.
                          Then all you have to do is select the previous printer to print without an end wait instead of changing the GCode every time.
                          PS:
                          Filaments can also be assigned an additional GCode.
                          So if only the PLA needs this waiting time or extra cooling for you.
                          Google Translate
                          Du könntest Dir ein weiteres Druckerprofil anlegen in dem Du diese Wartezeit im End GCode einfügst.
                          Dann brauchst Du nur noch den vorherigen Drucker auswählen um ohne End-Wartezeit zu drucken anstatt jedes mal den GCode zu ändern.
                          P.S.:
                          Auch Filamente können ein zusätzlichen GCode zugewiesen bekommen.
                          Also wenn bei Dir nur das PLA diese Wartezeit bzw extra Abkühlung benötigt.
                          Thingiverse
                            RatRig0331 @Norder
                            @norder oooo how would I assign additional cooling for PLA?
                            • Norderundefined
                              Norder @RatRig0331
                              @ratrig0331
                              Enter in the End-GCode of the filament that the fan you intended for it is switched on with M106, then with G4 a time how long the End-GCode should pause and then the M107 command to switch the fan off.
                              I haven't tried it myself, but as far as I understand it should work.
                              Learning by doing. 😄
                              Google Translate
                              Trage im End-GCode des Filaments ein das der Lüfter den Du dafür vorgesehen hast, mit M106 eingeschaltet wird, dann mit G4 eine Zeit wie lange der End-GCode pausieren soll und dann der M107 Befehl um den Lüfter aus zu schalten.
                              Ich habe es noch nicht selber probiert, aber nach meinem Verständnis müsste es funktionieren.
                              Thingiverse
                              • Norderundefined
                                Norder @Norder
                                If the PLA should be extra cooled right from the start, then write the M106 command in the Start-GCode of the filament.
                                And in the End-GCode there may be a pause to cool the filament even further after the end of the print until the G4 pause time has expired and then the M107 command comes as the last command to switch the fan off completely.
                                Google Translate
                                Soll das PLA gleich von Anfang an extra gekühlt werden, dann schreibe den M106 Befehl in den Start GCode des Filaments.
                                Und im End GCode eventuell eine Pause um nach Ende des Druckes das Filament noch weiter zu kühlen bis die G4 Pausenzeit abgelaufen ist und dann als letztes der M107 Befehl kommt um den Lüfter komplett aus zu schalten.
                                Thingiverse
