    Webpage not loading at all
    Duet Web Control
    • Thalanielundefined
      Thalaniel
      Duet web control page not loading:
      Your Duet rejected the HTTP request: page not found
      Check that the SD card is mounted and has the correct files in its /www folder
      Following files are in the folder:
      What else is required for this page to load?
      I was able to update the firmware on the card to the latest versionFIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.4.1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2022-06-01 21:07:06<LF>ok<LF>
      The wifi is now stable and connect without issue.
      still no access to the webpage.
      Thank you for you help.
      Thal
      • chrishammundefined
        chrishamm administrators @Thalaniel
        @thalaniel This is related to the same problem as in your other thread. Make sure the microSD card is properly inserted.
        Duet software engineer
