    Duet 3 Mini 5+ V1.02
    • Basilundefined
      Basil
      Did anybody know when the version V1.02 of the DUET 3 Mini5+ will be uploaded on the DUET site documentation?
      • T3P3Tonyundefined
        T3P3Tony administrators @Basil
        @basil thats added now:
        https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview#revision-history
        www.duet3d.com
        • Basilundefined
          Basil
          Many thanks for your reply Tony.
          It is understood that a new board, with the origininal configuration already ordered and not provided, will be suplied one more time when you have "reverted once supplies of the TQFP package become available" or, this your provisionaly proposed configuration, as it is version V1.02, comes to be an secure and guaranteed long term mainboard.
          Please clarify.
            dc42 administrators @Basil
            @basil we can't guarantee to make no further changes, for two reasons:
            1. We have a policy of continuous improvement, so we may bring out a future version of the Duet 3 Mini with improved functionality. For example, the version 1.02 board includes additional protection against the application of high voltages to the tacho inputs on the 4-wire fan connectors.
            2. The ongoing component shortage means that we are sometimes unable to purchase the components we need, which forces us to modify the board design to use alternative components. An example is the switch to the BGA package processor on the Duet 3 Mini WiFi 1.02 board.
            When we make changes, we always strive as far as possible not to remove or reduce any functionality. Where we cannot avoid reducing functionality, we give our OEM customers advance warning that the change is coming. We also strive to maintain firmware compatibility. Occasionally this means that older firmware versions will not run on new boards, but the newer firmware will always run on the older boards.
            HTH David
