    CNC Machine Compatibility
    • orc
      orc last edited by
      I would like to purchase the Duet to operate this machine:
      https://www.aliexpress.com/snapshot/7374711260.html?spm=a2g0s.9042647.6.2.2TOcRI&orderId=73201741777744&productId=32557955252
      It has NEMA23 motors with these specs
      "two-phase hybrid stepping motor , 1.8A/PHASE,40N.cm, 8 segments drive."
      Do you think it'll work?
        I'm sorry, that link doesn't work for me. I tried a few variation such as removing your order ID from the URL, but they didn't work either.
        The 1.8A rated current is OK.
        • orc
          orc last edited by
          For some reason it also seems I got a different motor than what specified
          This is what the data sheet says:
          It seems that this will be at the higer end of what the duet wifi can handle
          Is it okay or should I get external drivers?
          • elmoret
            elmoret last edited by
            You didn't embed the image, you embedded the site, therefore the image doesn't display in your post.
            A 2.8A rated stepper motor is a good match for a Duet Wifi, as generally one shouldn't exceed 85% of rated current on a stepper.
