    Stall detection work only with R0 and R1
    Duet Web Control
    • kgolgerundefined
      kgolger
      hello to all!
      Github Issue #559 (https://github.com/Duet3D/RepRapFirmware/issues/559😞 same issue on Release 3.4.1 on my Duet2 Wifi.
      If M915 was invoked with parameter R2 or R3 then no action was taken on a driver stall as if R0 had been used. R1 is working.
      rehome.g and driver_stall.g are stored in the /sys/ folder. Stallguard parameter are calibrated (M915 X Y S9 H200 F0 R3). Homing is without stallguard. M915 is active during printing (started from SD-card). Printing speed is 100-200mm/s. Stepper are 1.8deg (200steps/rot) with 160 esteps.
      M915 messages:
      20.8.2022, 14:57:07 |
      Driver 0: stall threshold 9, filter off, steps/sec 200 (39.9 mm/sec), coolstep 0, action on stall: run macro
      Driver 1: stall threshold 9, filter off, steps/sec 200 (39.9 mm/sec), coolstep 0, action on stall: run macro
      Driver 2: stall threshold 1, filter off, steps/sec 200 (8.0 mm/sec), coolstep 0, action on stall: none
      Driver 3: stall threshold 1, filter off, steps/sec 200 (8.1 mm/sec), coolstep 0, action on stall: none
      Driver 4: stall threshold 1, filter off, steps/sec 200 (40.0 mm/sec), coolstep 0, action on stall: none
      After these messages - no macro executing:
      20.8.2022, 14:58:23 Warning: Driver 0 stall
      20.8.2022, 14:58:15 Warning: Driver 0 stall Warning: Driver 0 stall Warning: Driver 0 stall
      20.8.2022, 14:57:44 Warning: Driver 1 stall
      20.8.2022, 14:57:40 Warning: Driver 1 stall Warning: Driver 1 stall
      20.8.2022, 14:57:35 Warning: Driver 1 stall Warning: Driver 1 stall
      my config.g:
      config.g
      Did I miss something?
      Thanks for help!
      wbr,
      Karl
      rockman256 created this issue in Duet3D/RepRapFirmware
      closed [Bug]: Stall detection work only with R0 & R1 #559
        jay_s_uk @kgolger
        @kgolger what are in your driver stall files?
