Z Probe missing trigger point
  • Hello there! I have set up all wiring on my duet wifi board, aswell as making all changes to the firmware. Everything is working as intended, but I do have some issues with the Z probe missing the trigger point.
    The Z Probe im using is 3DTouch from Geeetech which is a BLTouch clone. I have read through every post I can find related to the subject, but I still can't get my probe to avoid skipping the trigger points. From my understanding this is tweaked with the "P" parameter in the "G31 P25 X0 Y0 Z1 ; Set Z probe trigger value, offset and trigger height" command, but no matter what value I have tried so far the issue keeps on happening.
    Here is my config file:
    [[language]]
    ; Configuration file for Duet WiFi (firmware version 1.17)
    ; generated by RepRapFirmware Configuration Tool on Wed Oct 25 2017 13:35:35 GMT+0200 (Vest-Europa (sommertid))
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M667 S1 ; Select CoreXY mode
    M208 X290 Y290 Z290 S0 ; Set axis maxima
    M574 Z0 S0 ; Define active low and unused microswitches
    M574 X1 Y1 S1 ; Define active high microswitches
    M558 P5 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
    M557 X15:265 Y15:265 S100 ; Define mesh grid
    M92 X80 Y80 Z400 E100 ; Set steps per mm
    M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
    M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M143 S280 ; Set maximum heater temperature to 280C
    M307 H7 A-1 C-1 D-1
    M563 P0 D0 H1 ; Define tool 0
    M550 PJarans HEVO ; Set machine name
    M551 P********** ; Set password
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    deployprobe.g marco:
    [[language]]
    M280 P7 S10 I1
    retractprobe.g macro:
    [[language]]
    M280 P7 S90 I1
    While sending the deploy and retract macros manually it seems to almost get all the triggers, but ends up skipping one once in a while and then the alarm is triggered. When trying to run the test mode the pin goes up and down while the red LEd is constantly on(is it not supposed to turn off when the pin is down?) until it fails and released the alarm.
    I have not added any resistor to the probe and I can't seems to figure out wether I need one or not. The BLTouch seems to need a 240ohm resistor. When I got my 3DTouch it came with a 10k ohm resistor - which should be needed depending on the board, but I can't find any information on what makes the board need it or not.
    Thanks for any help!
  • Could this be related to signal interference? I got all my wires from the duet wifi and up to the extruder going side by side the whole way.
    When im doing a G29 command while the printer has not started printing anything it usually manages to get through the 9 points without failing. However when a print is started and the heat bed and extruder is active it rarely get past the third or fourth probe point.
    That might be due to interference, especially if it is triggering too early. Unfortunately the BLTouch is closed source, so there is no schematic that I can look at to determine how sensitive to interference it is. But if you have it connected to the Z probe input, adding a resistor of about 10K between the Z probe connector IN and 3V3 pins might help. Increasing the P parameter in the G31 command would also make it less susceptible to interference.
  • @dc42:
    I have not added the 10k resistor so I can give that a shot. If that does not help then I will try to isolate the cables. Thanks for the input!
  • @dc42:
    When you say add a 10k resistor to the IN connector, do you mean between the probe itself and the pin or IN between ground?
    I mean between the IN pin and the 3V3 pin.
  • @dc42:
    Oh, was not familiar with "3V3" pin, but a google search said that would be the 3.3v pin. All the pins on the board is 5v that it is connected to, so the resistor would be between z probe IN and the ground next to it? (tried that without any diffrence)
    I also came over this: https://plus.google.com/113792662927481823969/posts/Sfig2jd4bvM
    Seems like the ground on the z probe connector is not attached. Is that a possibility too? I guess I got some more trial and error to do. Will post back as soon as I get somewhere.
    Edit: A little more trial and error has been done. Neither of the resistors I have tried made any diffrence. Earlier I was able to finish probing from time to time, but now it seems like the probe won't manage to even track one hit without failing. I noticed that when I retract the probe I can hear three small buzzes before it releasing the alarm.
    I might try to reset all settings and do it from scratch on another port just to be sure that its not a mistake I have made.
  • Now it seems like my 3DTouch is not tracking any signal what so ever. It can not get through any probing points at all. The z probe value never changes to "1000" upon triggering it. Deploying and retracting works, however when retracting the probe goes into alarm mode. Could my probe be defective?
    Does the Bltouch documentation describe what conditions put it in alarm mode? It's closed source, so otherwise it's hard to know.
  • @dc42:
    Not as far as I know. Can't seem to find anything on it. As the probe was working from time to time earlier with the same setup I would assume its the probe. Its not triggering at all unless its in the alarm mode.
    Will probably buy a new probe soon ish, and this time an original bltouch. Got too much finals starting in my studies now so it might take some time before I post back with an update!
  • Alright, so it looks like it was an issue with the 3DTouch. I bought a BLTouch and got it installed today. So far no steps have been skipped!
