    Duet 3 SD 0 card not recognised
    Using Duet Controllers
    • Togmoreundefined
      Togmore
      I have just purchased a Duet3 mini ethernet and i cant get it to recognise the SD card in slot 0
      Sending M122 responds with" Card0 not detected" i have also replaced the cared from my working Duet 2 and receive the same response. Reading additional information on the posts it appears that this is a faulty card any help would be appreciated
        droftarts administrators
        @togmore please can you post the full M122 response?
        Togmoreundefined 1 Reply Last reply Reply Quote 0
        • Togmoreundefined
          Togmore @droftarts
          Thank you Ian new to this so i hope this is what you need
          @droftarts === Diagnostics ===
          RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus Ethernet (SBC mode)
          Board ID: Q0MXM-2296U-D65J0-40KM2-LT03Z-HG85Q
          Used output buffers: 1 of 40 (1 max)
          Static ram: 98732
          Dynamic ram: 92788 of which 0 recycled
          Never used RAM 53696, free system stack 152 words
          Tasks: Linux(ready,423) HEAT(blocked,362) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,362) TMC(blocked,123) MAIN(running,610) IDLE(ready,20) AIN(blocked,269)
          Owned mutexes: USB(MAIN)
          Last reset 00:00:22 ago, cause: power up
          Last software reset details not available
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
          Cache data hit count 58519423
          Slowest loop: 0.21ms; fastest: 0.00ms
          === Storage ===
          Free file entries: 10
          SD card 0 not detected, interface speed: 0.0MBytes/sec
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = -1 -1, chamberHeaters = -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is ready with "M122" in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === CAN ===
          Messages queued 113, send timeouts 112, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
          === SBC interface ===
          State: 0, failed transfers: 0
          Last transfer: 22510ms ago
          RX/TX seq numbers: 0/1
          SPI underruns 0, overruns 0
          Number of disconnects: 0, IAP RAM available 0x113e0
          Buffer RX/TX: 0/0-0
          ok
          droftartsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            droftarts administrators @Togmore
            @togmore the interface speed means that the SD socket is disconnected:
            It should be replaced under warranty. Where and when did you purchase it? Also, can you take a picture of the area around the SD card socket?
            • Togmoreundefined
              Togmore @droftarts
              @droftarts I Ian purchased from Ooznest Tuesday delivered Wednesday picture attached
              Steve
                @togmore I can’t see anything particularly wrong with the soldering, but it’s clearly not working.
                Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                Sorry for the inconvenience.
                  Phaedrux Moderator @Togmore
                  @togmore said in Duet 3 SD 0 card not recognised:
                  Can you confirm that it's not actually connected to a raspberry Pi?
