    Can't edit daemon.g file
    Using Duet Controllers
    • e4dundefined
      e4d
      Hello, I have an error when I want to edit the daemon.g file : "Error: Cannot delete file /sys/daemon.g because it is open"
      I thought it was because there is a while loop running in the daemon file so I tried using a runDeamon variable that could stop this while loop.
      Here's my daemon.g file :
      while global.runDaemon == true
          if global.var1== true
              ; suction
              if sensors.gpIn[0].value == 0 && sensors.gpIn[1].value == 1 ; high pressure
                  M42 P1 S1   ; start distr2
              if sensors.gpIn[0].value == 0 && sensors.gpIn[1].value == 0 ; low pressure
                  M42 P1 S0   ; stop distr2
          else
          G4 S1
      Can you please tell me how to bypass this problem ? Thanks
        jay_s_uk @e4d
        @e4d rename the daemon.g file and then you should be able to edit it
