Thermostatically controlled fan, sensor on different board
  • undefined
    p8blr
    I have a BMG-X2 that I setup with two toolboards and I'm only using one heatsink cooling fan connected to one toolboard. The fan doesn't function unless I have it controlled by a sensor on the same toolboard.
    M308 S1 P"21.temp0" Y"thermistor" T100000 B4680 C6.455513e-8
    M950 F0 C"22.out2" Q500
    M106 P0 S255 T45 H1:2 C"Heatsink Fan"
    According to the release notes though, it should work:
    "[Duet 3 with expansion/tool boards] Expansion boards now track the temperatures of all sensors in the system. This means that a thermostatic fan connected to an expansion board can now be controlled by sensor(s) on different expansion boards(s)."
    config.txt
    • undefined
      Can you post your full config.g and the results of sending M98 P"config.g" and M122 and M122 B# where # is the can address of your expansion boards?
      undefined 1 Reply Last reply 31 Aug 2022, 13:18 Reply Quote 0
      • undefined
        @p8blr this is a known bug, fixed in the imminent 3.4.2rc3 release.
        undefined 1 Reply Last reply 31 Aug 2022, 13:20 Reply Quote 0
        • undefined
          p8blr @Phaedrux
          @phaedrux
          My config file is a text file attachment on my original post.
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          M122
          RepRapFirmware for Duet 3 MB6HC version 3.4.1 (2022-06-01 21:09:01) running on Duet 3 MB6HC v1.01 or later (standalone mode)
          Board ID: 08DJM-9P63L-DJ3T0-6JKD0-3S46K-TU1R8
          Used output buffers: 6 of 40 (22 max)
          Static ram: 151000
          Dynamic ram: 96564 of which 288 recycled
          Never used RAM 102820, free system stack 188 words
          Tasks: NETWORK(ready,26.8%,209) ETHERNET(notifyWait,0.0%,168) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.8%,92) MAIN(running,65.3%,925) IDLE(ready,0.0%,30), total 100.0%
          Owned mutexes:
          Last reset 00:08:46 ago, cause: power up
          Last software reset at 2022-08-30 16:15, reason: HardFault undefInstr, GCodes spinning, available RAM 102860, slot 1
          Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00010000 ICSR 0x00400803 BFAR 0x00000000 SP 0x2041b508 Task MAIN Freestk 1672 ok
          Stack: 00000000 2042c2f8 00000000 00000000 000001cd 00457c9b 0045c898 610f0000 20419a8c 2042bf54 00000000 00000001 00000000 00484687 2042bf54 00000000 00000000 004849cf fffbfff0 00484ba7 2042c2f8 20429f48 00000000 2041b5a4 a5a5a5a5 0045c897 ffffffff
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 151
          MCU temperature: min 19.7, current 36.7, max 36.9
          Supply voltage: min 24.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0, mspos 8, reads 62152, writes 17 timeouts 0
          Driver 1: standstill, SG min 0, mspos 8, reads 62152, writes 17 timeouts 0
          Driver 2: standstill, SG min 0, mspos 8, reads 62152, writes 17 timeouts 0
          Driver 3: standstill, SG min 0, mspos 8, reads 62159, writes 11 timeouts 0
          Driver 4: standstill, SG min 0, mspos 8, reads 62159, writes 11 timeouts 0
          Driver 5: standstill, SG min 0, mspos 8, reads 62159, writes 11 timeouts 0
          Date/time: 2022-08-31 08:17:24
          Slowest loop: 10.47ms; fastest: 0.05ms
          === Storage ===
          Free file entries: 10
          SD card 0 detected, interface speed: 25.0MBytes/sec
          SD card longest read time 5.7ms, write time 0.0ms, max retries 0
          DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === CAN ===
          Messages queued 4794, received 18972, lost 0, boc 0
          Longest wait 3ms for reply type 6026, peak Tx sync delay 6, free buffers 50 (min 49), ts 2633/2632/0
          Tx timeouts 0,0,0,0,0,0
          === Network ===
          Slowest loop: 13.24ms; fastest: 0.02ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          - Ethernet -
          State: active
          Error counts: 0 0 1 0 0
          Socket states: 5 2 2 2 2 0 0 0
          M122 B21
          Diagnostics for board 21:
          Duet TOOL1LC rev 1.1 or later firmware version 3.4.1 (2022-06-01 21:16:39)
          Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
          All averaging filters OK
          Never used RAM 2800, free system stack 88 words
          Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,113) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.0%,57) MAIN(running,91.9%,341) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
          Last reset 00:08:53 ago, cause: power up
          Last software reset data not available
          Driver 0: pos 0, 415.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 15, reads 4516, writes 15, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x72, steps req 0 done 0
          Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
          Peak sync jitter 0/6, peak Rx sync delay 211, resyncs 0/0, no step interrupt scheduled
          VIN voltage: min 24.7, current 24.7, max 24.7
          MCU temperature: min 21.9C, current 39.1C, max 39.1C
          Last sensors broadcast 0x00000002 found 1 148 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 8561, send timeouts 0, received 6947, lost 0, free buffers 37, min 37, error reg 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
          Accelerometer: LIS3DH, status: 00
          I2C bus errors 0, naks 3, other errors 0
          M122 B22
          Diagnostics for board 22:
          Never used RAM 2624, free system stack 88 words
          Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,101) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,3.0%,57) MAIN(running,91.9%,341) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
          Last reset 00:08:55 ago, cause: power up
          Driver 0: pos 0, 415.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 15, reads 5341, writes 15, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
          Peak sync jitter 1/6, peak Rx sync delay 210, resyncs 0/0, no step interrupt scheduled
          VIN voltage: min 24.0, current 24.1, max 24.1
          MCU temperature: min 22.5C, current 37.7C, max 37.7C
          Last sensors broadcast 0x00000004 found 1 38 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 10734, send timeouts 0, received 6983, lost 0, free buffers 37, min 37, error reg 0
          • undefined
            p8blr @dc42
            @dc42 Oh good to know! I'll give that version a try and see if it fixes the issue.
            undefined 1 Reply Last reply 1 Sept 2022, 12:48 Reply Quote 0
            • undefined
              p8blr @p8blr
              @p8blr The new firmware fixed the issue! However, now I'm getting weird PID autotune errors, so I may make a new thread for that topic. Thank you for your help!
              1 out of 6
