No USB connection with MB6HC / no device manager visibility
Hey community,
i know that there are already a few threads like this but they do not help me in my problem or are not the same problem.
So i have a Duet3D MB6HC Board and want to follow https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet and connect via usb. But i do not see the board in the device manager and can not install the driver.
I already tried to different PCs with Linux and Windows and three different cables. The LEDs are correct.
So maybe someone has an idea for me
Thanks
Bowski -
@bowski you don't really need to connect via USB.
Just make sure you have a config on your sd card that containsM552 S1 P0.0.0.0
. At this stage it doesn't need to contain anything else.
You'll also need the www folder populated with DWC (DuetWebControl).
You'll then be able to access the board over ethernet -
@bowski said in No USB connection with MB6HC / no device manager visibility:
Is the red STATUS or DIAG LED flashing once per second; or lit very dimly and not flashing; or neither?
