    Warning: Lost connection to Duet (SPI connection
    925
    • A Former User?
      A Former User
      hello friends since yesterday I have this error which appears permanently on my duet 3 6hc.
        jay_s_uk @A Former User
        @sgk i would start by reseating the cable between the duet 6HC and the raspberry pi.
        Can you also post an image of where the cable between the two is situated?
        • A Former User?
          A Former User @jay_s_uk
            jay_s_uk
            @sgk what length is the cable that came supplied with the 6HC?
            • A Former User?
              @jay_s_uk 10 cm
              • A Former User?
                A Former User @A Former User
                @sgk
                I changed the rpi card but still the same error
                • A Former User?
                  I changed the sd card 3x install the firmware I don't know what to do anymore when I print the print I stop
                    @sgk don't use the pi? That would be my answer
                    • A Former User?
                      @jay_s_uk
                      do it work without the rpi I tried but I can't connect to the duet with the cable?
                      A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
                      • A Former User?
                        @sgk
                        when I go to follow the tutorial it sends me to the duet 2 wifi card
                        https://docs.duet3d.com/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
                        • A Former User?
                            Phaedrux Moderator @A Former User
                            @sgk said in Warning: Lost connection to Duet (SPI connection:
                            The Duet3 has an ethernet port, so all you really need is a working SD card with the DWC files in the /www folder and a config.g in the /sys folder. As long as you have M552 S1 in your config it should get an ip address from your router and you can connect to the web interface. USB isn't really required if you have a working setup already.
                            A Former User? 1 Reply Last reply Reply Quote 1
                            • A Former User?
                              A Former User @Phaedrux
                              @phaedrux
                              OK OK I understand better than tried I'm going to put ip directly on the config. But it's a shame that I can't use the rpi card, that's crazy.
                                There may be a problem with the cable or your board.
                                • A Former User?
                                  @phaedrux with the rpi
                                    There may be a problem with the cable connecting the Duet to the RPI or your clone duet board.
                                    • A Former User?
                                      @phaedrux yes ok i see there is a way to know? by changing the cable.
                                      • A Former User?
                                        It doesn't work but I think I made a mistake somewhere
                                        M552 S1 192.168.117 ; enable network and acquire dynamic address via DHCP
                                        M586 P0 S1 ; enable HTTP
                                        M586 P1 S0 ; disable FTP
                                        M586 P2 S0 ; disable Telnet
                                          192.168.117
                                          You only have 3 numbers.
                                          • A Former User?
                                            @phaedrux yes is my ip
