    Duet 3 Modify web control interface
    Duet Web Control
    • temisAPundefined
      temisAP
      Hi there,
      We are running a Duet 3 printer through a Raspberry Pi 4. As is well known, shutting down the Raspberry without command a "shutdown" can corrupt the SD and that's what happened to us 😞
      Because of that, instead of access to the Pi via SSH, command a "shutdown" and then turn off the power source, we'd like to add a button into the web control interface to run the command easily. Is there any way to modify the web control interface?
      Thanks
        jay_s_uk @temisAP
        @temisap use btncmd https://plugins.duet3d.com/plugins/BtnCmd.html and the execonmcode plugin https://plugins.duet3d.com/plugins/DSF_ExecOnMcode_Plugin.html
        I thought there was an mcode for it but there isn't
        M540 Set MAC address
        M550 Set Name
        M552 Set IP address, enable/disable network interface
        M553 Set Netmask
        M554 Set Gateway
        M586 Configure network protocols
        M587 Add WiFi host network to remembered list, or list remembered networks
        M588 Forget WiFi host network
        M589 Configure access point parameters
        M999 B-1 Reboot SBC
        Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
        • Rushmere3Dundefined
          Rushmere3D @jay_s_uk
          @jay_s_uk
          I use Execonmode but installed it the original way and they guide I followed, sets up M7722 as a shutdown code.
          Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
          jay_s_ukundefined 1 Reply Last reply Reply Quote 1
            jay_s_uk @Rushmere3D
            @rushmere3d i would consider upgrading to the new plugin as the old one is no longer being maintained
              @jay_s_uk I only use it for shutting down the Pi and if you saying it's not setup to do it why would I upgrade?
                @rushmere3d all i'm saying that going forwards if something changes in DSF that stops the original execonmcode from working, you'll have to upgrade anyway.
                  @jay_s_uk Well it seems to break when I update anyway, so next time I do, I'll try it out.
