Solved Wifi module disabled at start
@jay_s_uk Aha ok, so it's not stored in the config.g file then?
No, but the config file needs to have M552 S1 to enable the module at startup.
@phaedrux Hi,
I've been trying to migrate to RR3 for a coupple of days now but I just can't get it to work..
I've been using the config tool, but I can't see any diffrence in the gcode compared to my old config file, should it be so?I can't even home any of the axis...
This is my config.g file atm.
; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.12 on Wed Sep 14 2022 08:24:17 GMT+0200 (centraleuropeisk sommartid) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer test cartesian" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M584 X6 Y1 Z2:5:4 E3 ; set 3 Z drivers M569 P1 S0 ; Drive 1 goes backwards M569 P2 S0 ; Drive 2 goes backwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M569 P5 S0 ; Drive 5 goes backwards M569 P6 S1 ; Drive 6 goes forwards ; Defining X and Y coordinates of the leadscrews M671 X-80:580:580 Y245:490:0 S5 ; leadscrews at front right, rear right and middle left M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y240.00 Z200.00 E415.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X500 Y500 Z700 S0 ; set axis maxima ; Endstops M574 X1 S0 ; Set active low endstops M574 XY S1 ; set active high endstops M574 Z1 S2 ; set endstops controlled by probe ; Z-Probe M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch M558 P9 H5 F650 T9000 ; set Z probe type to bltouch and the dive height + speeds G31 P50 X0 Y0 Z4.5 ; set Z probe trigger value, offset and trigger height M557 X0:500 Y0:400 S100 ; define mesh grid ; Heaters M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S0.3 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
@haggan90 said in Wifi module disabled at start:
This config is still for RRF2. Did you select RRF3 in the config tool on the first page?
On the General tab, at the top, firmware version drop down should be 3.3 or later.
@phaedrux Ah, thanks!
Now I got it working, finaly!
I do have some problems with the endstops, sometimes they work and sometimes not. -
@haggan90 thanks, I'll mark this as solved. If you don't resolve the issues with the endstops, please start a separate thread for that.
