    Reading analog values from Laser Range Finder (6HC)
    • HebigTundefined
      HebigT
      I'm interested in using a non-contact sensor for a metrology-type project in which I 'probe' the surface of a print. The exact sensor is an omron ZX-LD30V from a decommissioned piece of equipment.
      http://products.omron.us/item/laser-displacement-sensors/zx-l-n/zx-ld30v
      I'm using a Duet 3 and it looks like most I/O connections can be set up as Z-probes - does that mean these can be used as analog inputs?
      If the omron sensor outputs a 1-5v signal, can I then read these signals into the object model and use them in a macro?
      • chrishammundefined
        chrishamm administrators @HebigT
        @hebigt Not all input ports are connected to the ADC, see https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6HC_Hardware_Overview#io-headers. Also note that the ADC expects 3.3V, not 5V, so you may want to add a voltage divider if you need the full output range of your sensor.
        Other than that it is perfectly fine to set up an analog Z-probe.
        Duet software engineer
        HebigTundefined 1 Reply Last reply Reply Quote 1
        • HebigTundefined HebigT marked this topic as a question
        • HebigTundefined HebigT has marked this topic as solved
        • HebigTundefined
          HebigT @chrishamm
          @chrishamm
          Thanks for that, this is helpful!
          • HebigTundefined HebigT referenced this topic
