    Hotend temp fault. Reading 425c with no connection.
    336
    • Mr_Phelpsundefined
      Mr_Phelps
      I am running Duet 3 MB6HC with Toolboard Ver. 1.2, both at 3.4.1
      I saw a few 2000c errors before that cleared with a power cycle.
      Running a Ratrig VCore 3 500
      Here is the M122 messages.
      9/20/2022, 7:03:30 PM M122 B121.0
      Diagnostics for board 121:
      Duet TOOL1LC rev 1.1 or later firmware version 3.4.1 (2022-06-01 21:16:39)
      Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
      All averaging filters OK
      Never used RAM 2592, free system stack 88 words
      Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,61) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.0%,57) MAIN(running,91.9%,351) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
      Last reset 00:21:40 ago, cause: power up
      Last software reset data not available
      Driver 0: pos 0, 830.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 60527, writes 14, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter 1/6, peak Rx sync delay 213, resyncs 0/0, no step interrupt scheduled
      VIN voltage: min 23.7, current 23.7, max 23.7
      MCU temperature: min 37.4C, current 40.1C, max 40.1C
      Last sensors broadcast 0x00000002 found 1 16 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 26019, send timeouts 0, received 11720, lost 0, free buffers 37, min 37, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
      Accelerometer: LIS3DH, status: 00
      I2C bus errors 0, naks 3, other errors 0
      9/20/2022, 7:02:55 PM M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.1 (2022-06-01 21:09:01) running on Duet 3 MB6HC v1.01 or later (standalone mode)
      Board ID: 08DJM-956BA-NA3TJ-6J1FD-3S06T-KU8UT
      Used output buffers: 1 of 40 (13 max)
      Static ram: 151000
      Dynamic ram: 95884 of which 520 recycled
      Never used RAM 103268, free system stack 200 words
      Tasks: NETWORK(ready,27.5%,209) ETHERNET(notifyWait,0.1%,173) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.7%,92) MAIN(running,64.7%,925) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes:
      Last reset 00:21:05 ago, cause: power up
      Last software reset at 2022-09-18 09:47, reason: User, GCodes spinning, available RAM 99788, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 142
      MCU temperature: min 25.7, current 38.5, max 38.8
      Supply voltage: min 23.8, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
      Events: 1 queued, 1 completed
      Driver 0: standstill, SG min 0, mspos 8, reads 13859, writes 15 timeouts 0
      Driver 1: standstill, SG min 0, mspos 8, reads 13859, writes 15 timeouts 0
      Driver 2: standstill, SG min 0, mspos 8, reads 13859, writes 15 timeouts 0
      Driver 3: standstill, SG min 0, mspos 8, reads 13859, writes 15 timeouts 0
      Driver 4: standstill, SG min 0, mspos 8, reads 13859, writes 15 timeouts 0
      Driver 5: standstill, SG min 0, mspos 8, reads 13862, writes 12 timeouts 0
      Date/time: 2022-09-20 19:02:54
      Slowest loop: 11.08ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 3.3ms, write time 0.0ms, max retries 0
      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 11398, received 25292, lost 0, boc 0
      Longest wait 3ms for reply type 6053, peak Tx sync delay 268, free buffers 50 (min 49), ts 6329/6328/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 22.49ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      • Ethernet -
        State: active
        Error counts: 0 0 0 0 0
        Socket states: 5 2 2 2 2 0 0 0
        Mr_Phelps
        I should point out that two different hotends report the same behavior and I can measure the resistance of the thermistor all the way to the toolboard.
          What's the exact fault message?
          What does the temp graph look like?
          Please post your config.g
          Mr_Phelpsundefined 1 Reply Last reply Reply Quote 0
            Mr_Phelps @Phaedrux
            @phaedrux
            Sorry, should have given more info. Was a late night and a little bit frustrated.
            The Ver 1.2 toolboard had probably close to 200 hours of print time. The printer was working with mostly just chasing some movement issues around small, rapid movements.
            I saw an error of 2000c on the hotend thermistor a couple of times that I was able to fix with a power cycle. But then the toolboard faulted out and was stuck at 423c whether a thermistor was connected or not.
            I have since wired the hotend thermistor directly to the 6HC and it reads correctly. So definitely a problem with the toolboard. Is this a warrenty thing or do I have to buy a replacement board?
            Thanks,
            Mike
              Can you post your config.g?
              It may be warranty, when and where was it purchased?
                Mr_Phelps @Phaedrux
                @phaedrux
                Purchased June 4, 2022 from Matterhackers in the US.
                I have the Rapido thermistor directly connected to the Duet 3 6HC on Temp1. Though now I'm getting "Heater 1 fault: failed to read sensor: unknown sensor." which is old, since I was running a direct connection before I put the toolboard in. 😕 I may just have syntax wrong somewhere.
                ; config.g
                ; RepRapFirmware 3.4.0 configuration for V-Core 3 500x500 with
                ; - Duet 3 Mainboard 6HC
                ; - Duet 3 Toolboard 1LC (on default CAN ID #121)
                ; - Duet Paneldue 7i (not yet)
                ; - Duet Filament Monitor (not yet)
                ; - Super PINDA
                ; - Keenovo silicone heater pad 480x480 (1500W) 110V
                ; - Keenovo C-Lin SSR 40A440VAC solid state relay
                ; - Phateus Rapoido Hotend
                ; - 104NT-4-Ro25H42G/ Element's maximum heat resistance : 290c
                ; - BondTech LGX extruder (e-steps value : 400 using 32 microsteps, stepper 1.8 current rating: 1A/Phase, recomended 0.45A - 0.6A max 0.7A) (need to check this)
                ; - Steppers X,Y and Z: LDO 1.8 48mm LDO-42STH47-2504AC (current rating: 2.5A/Phase)
                G4 S3 ; wait for tool board to start
                M550 P"V-Core 3" ; set printer name
                M669 K1 ; CoreXY
                G29 S1 ; Set Units to Millimeters
                M552 P192.168.1.100 S1 ; enable network and assign adx
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P0.0 S0 D3 ; physical drive 0.0 goes forwards
                M569 P0.1 S0 D3 ; physical drive 0.1 goes forwards
                M569 P0.2 S0 D3 ; physical drive 0.2 goes forwards
                M569 P0.3 S1 D3 ; physical drive 0.3 goes forwards
                M569 P0.4 S1 D3 ; physical drive 0.4 goes forwards
                M569 P0.5 S1 D3 ; physical drive 0.5 goes forwards
                M584 X0.4 Y0.3 Z0.0:0.1:0.2 E121.0 ; set drive mapping
                M350 X16 Y16 Z16 E32 I1 ; configure microstepping with interpolation
                M92 X80.00 Y80.00 Z800.00 ; set steps per mm
                ;M906 X1600 Y1600 Z1600 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M566 X4000.00 Y4000.00 Z6.00 E2000.00 P1 ; set maximum instantaneous speed changes (mm/min)
                M203 X8000.00 Y8000.00 Z300.00 E3600.00 ; set maximum speeds (mm/min)
                ;M203 X10800.00 Y10800.00 Z1000.00 E3600.00 ; Increase it up when you have it all working set maximum speeds (mm/min)
                M201 X3000.00 Y3000.00 Z200.00 E2400.00 ; set accelerations (mm/s^2)
                ;M201 X3000.00 Y3000.00 Z100.00 E3600.00 ; Increase it when you have it all working set accelerations (mm/s^2)
                ;Driver Current -Affected by speed. if you go over 6000 Accel you will need more current.
                M906 X1600 Y1600 Z1600 E600 I50 ; Z is very heavy on 500 I needed 1000+ set motor currents (mA) and motor idle factor in percent
                M208 X510 Y500 Z500 S0 ; set axis maxima
                M574 X1 S1 P"121.io1.in" ; configure active high endstops
                M574 Y2 S1 P"io1.in" ; configure active high endstops
                M671 X-4.5:250:504.5 Y-4.52:505:-4.52 S5 ; define positions of Z leadscrews or bed levelling screws
                M557 X25:475 Y25:475 P7 ; define 7x7 mesh grid
                M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed" ; configure sensor 0 as thermistor on pin temp0
                M950 H0 C"out1" T0 ; create bed heater output on out5 and map it to sensor 0
                M143 H0 S110 ; set temperature limit for heater 0 to 110C
                ;; Run Bed PID Tune!! Bellow is an example for a 300x300 bed
                M307 H0 B0 R0.162 C521.5 D1.74 S1.00 V23.8
                ;; M307 H1 A303.1 C356.7 D1.4 S1.00 V24.0 B0
                M950 F0 C"121.out2" Q500 ; create fan 1 on pin out3 and set its frequency
                M106 P0 C"Hotend Fan" S0 H1 T45 L255 ; set fan 1 name and value. Thermostatic control turned on for Hotend
                M950 F1 C"121.out1" Q500 ; create fan 0 on pin out4 and set its frequency
                ;M950 F0 C"out4+out4.tach" Q500
                ;M106 P0 C"Layer Fan" S0 H-1 L255 ; set fan 0 name and value. Thermostatic control is turned off
                M106 P1 C"Layer Fan" S0 H-1
                M563 P0 D0 H1 F1 ; define tool 0
                G10 P0 X0 Y0 Z0.0 ; set tool 0 axis offsets
                M950 H1 C"121.out0" T1 ; create nozzle heater output on out2 and map it to sensor 1
                M307 H1 R4.098 K0.573:0.233 D4.53 E1.35 S1.00 B0 V23.4 ;output from PID tune - for Rapido
                ;M307 H1 R4.590 K0.563:0.541 D1.37 E1.35 S1.00 B0 V23.5 ;output from PID tune - old for Revo
                M143 H1 S300 ; set the maximum temperature in C for heater
                ; EVA 3 / LGX / Rapido
                M92 E830 ; set extruder steps per mm, 0.9 angle/step (LDO Pancake)
                M906 E800 ; set extruder motor current (mA) and idle factor in per cent
                ;M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend"
                M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend"
                ;; Run Heater PID Tune!!
                ;; M307 H2 A751.5 C196.6 D4.7 S1.00 V23.9 B0
                ;; Inductive Probe
                M557 X10:480 Y10:480 S30 ;Set mesh grid
                M558 P8 C"121.io2.in" H5 F400 T5000 A5 ; set Z probe type to unmodulated and the dive height + speeds
                G31 P500 X-30 Y-15 Z0.52 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
                ;Accelerometer
                M955 P121.0 I10 ; specify orientation of accelerometer on Toolboard 1LC with CAN address 121
                M593 P"mzv" F37
                T0
                ; Pressure Advance
                M572 D0 S0.05
                Mr_Phelpsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  Mr_Phelps @Mr_Phelps
                  @mr_phelps
                  Oops, forgot to say that the sensor is currently reading the correct ambient temperature. Same as the bed thermistor.
                    @mr_phelps
                    I've switched to the second thermistor input and that is working. So I'm back to printing! 🙂
                      For the toolboard reading 425c constantly it's likely that a short (possibly from a flaky thermistor?) or ESD event has damaged the sense resistor. Is the toolboard and hotend grounded?
                        Phaedrux Moderator @Mr_Phelps
                        @mr_phelps said in Hotend temp fault. Reading 425c with no connection.:
                        I have the Rapido thermistor directly connected to the Duet 3 6HC on Temp1. Though now I'm getting "Heater 1 fault: failed to read sensor: unknown sensor." which is old, since I was running a direct connection before I put the toolboard in. I may just have syntax wrong somewhere.
                        Did you change the syntax? It looked ok from what you posted.
                        Is that thermistor working or not?
                          Mr_Phelps @Phaedrux
                          @phaedrux
                          Sorry, too many irons in the fire...
                          Not sure about grounding on the EVA, so probably not. I'll have to look into that.
                          I've been running without issue on the second thermistor.
                          I'll try a quick look at the sense resistor the next time I have some spare cycles.
                          Thanks for the info!
