    Drag&Drop + single file upload not working for filaments
    Duet Web Control
    • Exerqtorundefined
      Exerqtor
      Tried updating my filament configs just now, and like the header says i don't work to drag&drop or upload single files.
      If i zip up the load.g, unload.g & config.g in a .zip and manually locate them thru the DWC upload interface i get the error "Upload Filament Configs
      This ZIP does not contain any usable fiels".
      EDIT:
      Forgot to mention that i'm on DWC 3.4.2 @ chrome for PC.
        Has this worked successfully previously?
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @Phaedrux
          @phaedrux
          Tbh i have no idea since it's the first time editing the filament config outside DWC, but it SHOULD work? Shouldn't it? 🤣
            @chrishamm should it?
            • Exerqtorundefined
              Exerqtor @Phaedrux
              @phaedrux Judging by the info prompt you get if you hover over the upload button i would surely say so?
              • chrishammundefined
                chrishamm administrators @Exerqtor
                @exerqtor @Phaedrux At present only the three default macro files load.g, config.g, and unload.g are officially supported. You can upload entire filament configs but only if you download the corresponding filament directories first as ZIP files. Those three files must reside in a subdirectory, else you will get the error message that you mentioned.
                This will be changed in the future but I cannot give you an ETA yet.
                Duet software engineer
