    Setting up Slicer, G80-command
    Using Duet Controllers
    480
    • TomasLundefined
      TomasL
      Setting up superslicer, in the intro g-code there is an G80 command for mesh leveling, but it is not supported afaik.
      THe start code looks like this
      Using Duet2WiFi
      Prusa Steel with Hermera Directdrive
      M862.3 P "[printer_model]" ; printer model check
      M862.1 P[nozzle_diameter] ; nozzle diameter check
      M115 U3.10.1 ; tell printer latest fw version
      G90 ; use absolute coordinates
      M83 ; extruder relative mode
      M104 S{first_layer_temperature+extruder_temperature_offset} ; set extruder temp
      M140 S[first_layer_bed_temperature] ; set bed temp
      M190 S[first_layer_bed_temperature] ; wait for bed temp
      M109 S{first_layer_temperature+extruder_temperature_offset} ; wait for extruder temp
      G28 W ; home all without mesh bed level
      G80 ; mesh bed leveling
      G1 Z0.2 F720
      G1 Y-3 F1000 ; go outside print area
      G92 E0
      G1 X60 E9 F1000 ; intro line
      G1 X100 E12.5 F1000 ; intro line
      G92 E0
      What should be omitted and what should be added.
        jay_s_uk @TomasL
        @tomasl look at G29
        TomasLundefined 1 Reply Last reply Reply Quote 0
        • TomasLundefined
          TomasL @jay_s_uk
          @jay_s_uk
          Do one need to run a complete mesh compensation before every job.
            jay_s_uk @TomasL
            @tomasl no, you can load a saved one.
            https://docs.duet3d.com/en/User_manual/Reference/Gcodes#g29-mesh-bed-probe
            • TomasLundefined
              TomasL @jay_s_uk
              @jay_s_uk
              Yes I thought so, so the G29 command is not required in the start-up code
              • TomasLundefined
                TomasL @TomasL
                @tomasl
                Now in generated G-code I get the following unsupported commands
                M900 K0.05 ; Filament gcode LA 1.5
                M900 K30 ; Filament gcode LA 1.0
                • TomasLundefined
                  TomasL @TomasL
                  @tomasl Never mind, found it in the filiament section and commented it out.
                    It sounds like you may have the wrong gcode flavor selected. It should be set to RepRap.
                    • TomasLundefined
                      TomasL @Phaedrux
                      @phaedrux RepRap is selected, double checked this, apperantly it is supported in standard RepRap, Duetversion of RepRap is not an option, just standard RepRap
                        Standard RepRap should be fine.
