    Duet WiFi 1.02 or later + DueX5
    • Karimundefined
      Karim
      Hey guys what's the latest firmware for Duet WiFi 1.02 or later + DueX5.
      Thank You.
        You can always find the latest here: https://github.com/Duet3D/RepRapFirmware/releases
        Karimundefined 1 Reply Last reply Reply Quote 0
        • Karimundefined
          Karim @Phaedrux
          @phaedrux which one do I need . Duet2and3Firmware-3.4.2.zip
            Yes that's the one, but depending on how you're currently connected to the board it may require some different methods to update the firmware.
            If you have access to the web interface already you can upload that zip file to the settings tab and it will update everything automatically.
            If you're not already connected to the web interface I suggest you start with that.
            https://docs.duet3d.com/User_manual/Overview/Getting_started_Duet_2_WiFi_Ethernet
            https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
            • Karimundefined
              Karim @Phaedrux
              @phaedrux I am using the web interface .
              • Karimundefined
                Karim
                I got it to update, I had to update to 3 then 3.2.
