    Duet 2 Wifi & Duet 3 Mini 5+ SD Card Slot Faulty
    307
    • LevelFunundefined
      LevelFun
      I purchased my Duet 2 Wifi in 2019 and my Duet 3 Mini 5+ Ethernet in January of 2020 (it was RMA'd under warranty the day after receiving and I received a fresh new one via Filatruder). Life happened and I wasn't able to use them, so I kept them in their boxes and set them to the side. Fast-forward to today - finally excited to have free time and build my dream delta printers. Set everything up with my Duet 2 Wifi (which I tested back in the day) and YAT informs me of the following:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2 (2022-09-13 15:11:16) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3SJ-6JKFD-3SJ6T-TBYBH
      Used output buffers: 1 of 26 (11 max)
      Static ram: 23860
      Dynamic ram: 73376 of which 12 recycled
      Never used RAM 14832, free system stack 193 words
      Tasks: NETWORK(ready,7.7%,517) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,363) MAIN(running,92.3%,428) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes: USB(MAIN)
      Last reset 00:02:01 ago, cause: power up
      Last software reset at 2021-10-05 15:42, reason: User, GCodes spinning, available RAM 12656, slot 1
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 21.6, current 22.9, max 23.3
      Supply voltage: min 1.5, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
      Events: 0 queued, 0 completed
      Driver 0: ok, SG min n/a
      Driver 1: ok, SG min n/a
      Driver 2: ok, SG min n/a
      Driver 3: ok, SG min n/a
      Driver 4: ok, SG min n/a
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Slowest loop: 0.23ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      SD card 0 not detected, interface speed: 30.0MBytes/sec
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 0.20ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      = WiFi =
      Network state is disabled
      WiFi module is disabled
      Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
      ok
      (Yes I disabled the network after testing with it on, too)
      I figured, based off of reading up on the Duet3d forums, that the sd card socket is faulty per the images shown (that match my sd card solder points) and the response from YAT.
      I set it aside and pull out the Duet 3 Mini 5+ and give it a whirl, hoping I can at least start building the printer and use this board instead, choosing to deal with the Duet 2 Wifi at a later date. I somehow update the firmware then try to connect to the Duet Web Server and I am rejected. I open YAT and run M122 and get the following:
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.4.2 (2022-09-13 15:14:33) running on Duet 3 Mini5plus Ethernet (standalone mode)
      Board ID: ZTVJA-K396U-D65J0-40KMG-JN03Z-76KJK
      Used output buffers: 1 of 40 (1 max)
      Static ram: 103684
      Dynamic ram: 103264 of which 0 recycled
      Never used RAM 34764, free system stack 160 words
      Tasks: NETWORK(ready,6.8%,547) HEAT(notifyWait,0.0%,374) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,341) TMC(notifyWait,0.0%,124) MAIN(running,57.7%,613) IDLE(ready,34.6%,30) AIN(delaying,0.9%,271), total 100.0%
      Last reset 00:00:21 ago, cause: power up
      Last software reset details not available
      Error status: 0x00
      MCU revision 3, ADC conversions started 22036, completed 22035, timed out 0, errs 0
      Step timer max interval 660
      MCU temperature: min 23.1, current 24.0, max 24.2
      Supply voltage: min 0.4, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 6: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Cache data hit count 29809916
      Slowest loop: 0.20ms; fastest: 0.12ms
      === Storage ===
      SD card 0 detected, interface speed: 0.2MBytes/sec
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      SBC is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 108, received 0, lost 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 108/0/0
      Tx timeouts 0,0,107,0,0,0 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 0.18ms; fastest: 0.01ms
      = Ethernet =
      State: disabled
      Error counts: 0 0 0 0 0 0
      ok
      (Yes, I disabled the network after testing with it on, too)
      Am I cursed with the worst luck when it comes to Duet3d Boards? I tried multiple SD cards. All of them formatted with SD Card Formatter that I downloaded per the Duet3d instructions. All the SD cards are between 8-32gb. All formatted correctly.
      Seeing as I purchased these boards over 2 years ago, they're clearly out of warranty, yet brand new ๐Ÿ˜ž Please help. I've been troubleshooting trying everything I can for 2 days.
      I'm attaching 2 images of each board's SD solder points.
        I think you may be cursed.
        When and where exactly did you purchase the boards?
        LevelFunundefined 1 Reply Last reply Reply Quote 0
        • LevelFunundefined
          LevelFun @Phaedrux
          @phaedrux After searching through my old e-mails I actually purchased the Duet 3 Mini 5+ from Filastruder on January 6th, 2021 (my first Duet 3 Mini 5+ from Filastruder was RMA'd immediately after it arrived because it was faulty. The return was approved back then here on the forum and exchanged for a new one after more came in stock after a month.)
          My Duet 2 Wifi I am still trying to find where I purchased it from, but I know it was in 2020. I just can't catch a break with these board ๐Ÿ˜ž I love the support and RepRap over Marlin etc, but I don't know what to do now. Advice?
            We can deal with the Mini5 now, and if you can figure out where the Duet2 is from we can probably work out something on that as well.
            For the Mini5, Please send an email toย warranty@duet3d.comย and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
            • LevelFunundefined
              LevelFun @Phaedrux
              @phaedrux Will do. Thanks a bunch. I'll also post once I also find my Duet 2 Wifi receipt.
              • LevelFunundefined
                LevelFun
                @phaedrux I found my Duet 2 Wifi receipt from Printed Solid on March 2, 2020. Any way I can still send this in for repair since the SD card solder points are faulty? Thank you for your help!
                  Phaedrux Moderator @LevelFun
                  @levelfun said in Duet 2 Wifi & Duet 3 Mini 5+ SD Card Slot Faulty:
                  Please send another email for this board as well.
                  • LevelFunundefined
                    LevelFun @Phaedrux
                    @phaedrux Sent. Thank you again for all your help!
                      Sorry for the inconvenience.
