    Weird behavior of Y motor
    • DR8
      DR8 last edited by
      Running 1.19 firmware on duet wifi, powered at 24V on a corexy mechanics. Looking at this link, https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_CoreXY_printer
      the right settings are:
      I did three prints with this setting, all of them took like 3 hours and the printer run perfectly. But sudently, when I wanted to run another one, the Y motor direction has changed. And I don't understand why. Now, in order to have the right motion I have changed the Y direction:
      But why did that happend?
        Probably because you upgraded the firmware from 1.18 or earlier to 1.19 or later, and didn't read that part of the upgrade notes.
        • DR8
          DR8 last edited by
          The board came allready with 1.19 installed.
            The only reasons I can think of why the Y motor direction would change are:
            1. Firmware - as noted above, I made a change between 1.18 and 1.19, to bring RRF in line with other firmwares.
            2. A change to the M569 commands in config.g, or an M569 command in some other file that is getting executed. [But AFAIK, no slicers generate M569.]
            3. Reversing the Y motor connector, or swapping the wires of one of the phases in the Y motor connector. This could happen if you changed the Y motor cable.
