Z height and baby stepping in conflict?
Hello. I have noticed something:
In the image you can see the Z height reported by DWC. But that is the first layer being printed. It should be 0.2
In the capture you can see that I had to add a baby stepping of -0.45 (my Z offset was too heigh, I knew it from the beggining)
I have double checked the gcode and it is ok, first layer start printing at 0.2:
; head speed 10.000000, filament speed 0.000000, preload 0.000000
G1 X226.02 Y140.091 Z1.2 E0 F240
; 'Raft Path', 1.7 [feed mm/s], 9.1 [head mm/s]
G1 X136.682 Y206.799 E0 F12000
G1 X136.682 Y206.799 Z0.2 E0 F240
; 'Destring Prime'
G1 E1 F1125
; head speed 9.090909, filament speed 1.663007, preload 0.000000
G1 X136.671 Y206.681 E0.02167 F545.5So the gcode is actually being sent to 0.2
SO why Im readin on DWC a Z height of 0.45?
And it goes further: I can see the printing mving to layer number 2, and the Z height on the DWC is still 0.45?!
Baby stepping is an after the fact correction to get your to the correct position so it's not going to modify the expected height. Does that make sense?
@phaedrux but why im seeing those values on the interface?
Share your config.g, slicer start gcode, homing files, and the gcode file in question. Firmware and DWC version?
