    Cannot get extruder heater to turn on
    Using Duet Controllers
    • Feynman137undefined
      Feynman137
      I have a coreXY machine running with duet mainboard 6HC and raspberry pi. I am having issues getting the extruder heater to become active. The bed heaters work, but when I type in a temperature SP for the extruder heater it won't become "active". Does anyone know why this is?
      I'm not sure if there is an issue with my config file. But this used to work for me until I recently replaced both my duet board and raspberry pi due to some electrical frying :(.
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 23 2021 23:47:21 GMT-0400 (Eastern Daylight Time)
      G90                                             ; send absolute coordinates...
      M83                                             ; ...but relative extruder moves
      M550 P"Duet 3"                                  ; set printer name
      M669 K1                                         ; select CoreXY mode
      M569 P0.0 S1                                    ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                    ; physical drive 0.1 goes forwards
      M569 P0.2 S1									; physical drive 0.2 goes forwards
      M569 P0.3 S1									; physical drive 0.3 goes forwards
      M569 P0.4 S1									; physical drive 0.4 goes forwards
      M569 P0.5 S1									; physical drive 0.5 goes forwards
      M569 P1.1 S0                                    ; physical drive 1.1 goes backwards
      M569 P1.2 S1                                    ; physical drive 1.2 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.1:1.2        ; set drive mapping
      M671 X683.45:683.45:-106.25:-106.25 Y-30.12:513.52:513.52:-30.12 S1 			; leadscrews at (xf,yi) (xf,yf) (xi,yf) (xi,yi)
      M350 X16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
      M92 X40.00 Y40.00 Z1200.00 E837.00:837.00        ; set steps per mm
      M566 X900.00 Y900.00 Z150.00 E120.00:120.00      ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z300.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z10.00 E250.00:250.00      ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1500 E800:800 I30             ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                         ; Set idle timeout
      M208 X0 Y0 Z-2 S1                              ; set axis minima
      M208 X600 Y500 Z451 S0                          ; set axis maxima
      M574 X1 S1 P"!io4.in"                           ; configure active-low endstop for low end on X via pin !io1.in
      M574 Y1 S1 P"!io5.in"                           ; configure active-low endstop for low end on Y via pin !io5.in
      M574 Z2 S1 P"!io3.in"                           ; configure active-low endstop for low end on Z via pin !io3.in
      M950 S0 C"io7.out"                              ; create servo pin 0 for BLTouch
      M558 P9 C"^io7.in" H2 F100:50 T3000                ; set Z probe type to bltouch and the dive height + speeds
      G31 X0 Y0 Z4.1                          ; set Z probe trigger value, offset and trigger height
      M557 X50:550 Y50:450 S100                        ; define mesh grid
      M308 S0 P"1.temp0" Y"thermistor" T100000 B4138  ; configure sensor 0 as thermistor on expansion board pin 1.temp0
      M950 H0 C"1.out0" T0                            ; create nozzle heater output on 1.out0 and map it to sensor 0
      M307 H0 R2.440 K0.423 D6.88 E1.35 S1.00 B0 V23.9; disable bang-bang mode for heater  and set PWM limit
      M143 H0 S280                                    ; set temperature limit for heater 0 to 280C
      M308 S1 P"1.temp1" Y"thermistor" T100000 B4138  ; configure sensor 2 as thermistor on expansion board pin 1.temp1
      M950 H1 C"1.out1" T1                            ; create nozzle heater output on 1.out2 and map it to sensor 1
      M307 H1 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                    ; set temperature limit for heater 1 to 280C
      ; bed heater0
      M308 S2 P"0.temp0" Y"thermistor" T100000 B4138    ; configure sensor 2 as thermistor on mainboard pin temp0
      M950 H2 C"0.out9" T2                            ; create bed heater output on 1.out0 and map it to sensor 2
      M140 P0 H2                                         ;assign H2 to bed heater0
      M307 H2 B0 S10.00                                ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H2 S120                                     ;set temperature limit for heater 0 to 120C
      ; bed heater1
      M308 S3 P"0.temp1" Y"thermistor" T100000 B4138    ; configure sensor 3 as thermistor on mainboard pin temp1
      M950 H3 C"0.out6" T3                             ; create bed heater output on 1.out0 and map it to sensor 3
      M140 P1 H3                                         ;assign H2 to bed heater0
      M307 H3 B0 S10.00                                ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H3 S120                                     ;set temperature limit for heater 0 to 120C
      ; bed heater2
      M308 S4 P"0.temp2" Y"thermistor" T100000 B4138    ; configure sensor 4 as thermistor on mainboard pin temp2
      M950 H4 C"0.out5" T4                             ; create bed heater output on 1.out0 and map it to sensor 4
      M140 P2 H4                                          ;assign H2 to bed heater0
      M307 H4 B0 S10.00                                ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H4 S120                                     ;set temperature limit for heater 0 to 120C
      ; bed heater3
      M308 S5 P"0.temp3" Y"thermistor" T100000 B4138    ; configure sensor 5 as thermistor on mainboard pin temp3
      M950 H5 C"0.out4" T5                             ; create bed heater output on 1.out0 and map it to sensor 5
      M140 P3 H5                                      ;assign H2 to bed heater0
      M307 H5 B0 S10.00                                ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H5 S120                                     ;set temperature limit for heater 0 to 120C
      M950 F0 C"1.out7" Q500                          ; create fan 0 on pin 1.out7 and set its frequency
      M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"1.out8" Q500                          ; create fan 1 on pin 1.out8 and set its frequency
      M106 P1 S1 H-1                                  ; set fan 1 value. Thermostatic control is turned off
      M563 P0 D0 H0 F0                                ; define tool 0
      G10 P0 X23.9 Y-28.21 Z0                          ; set tool 0 axis offsets
      G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H1 F1                                ; define tool 1
      G10 P1 X-23.9 Y-28.21 Z0                         ; set tool 1 axis offsets
      G10 P1 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
      M575 P1 S1 B57600                               ; enable support for PanelDue
        You must select the tool first before the heater can become active.
        Click on Tool 0 or Tool 1 to have the active temperature
        It also looks like you might have a issue with your Tool1 termistor as it's showing -273c
        Feynman137undefined 1 Reply Last reply Reply Quote 0
          Feynman137 @Phaedrux
          @phaedrux if you are talking about clicking here (where I have underlined in blue) this does not work for me. I don't have Tool 1 connected that's why it is showing -273C.
          I have tried clicking both the tool0 and heater0 and neither will activate the heater but I get no warning messages
            Feynman137
            @feynman137
            It appears the issue was incompatible firmware between the expansion board and my mainboard but I issued the M997 command and now I can turn on the heater.
