problems with updating DUET WIFI 1.05+DUEX0.11
i updated duet 2 wifi 1.04 RFF3.3 to duet 2 wifi 1.05 RFF3.42 after doing this update it doesn't work E0 = NEMA17 E1 = NEMA17 why?
everything else works fine only the extruder motors do not work, the cables are working I tried them and the motors too
before doing this upgrade everything worked.
with the command M302 P1 cold extrusion but the motors do not turn
config (38).g
console.txt
@paolozampini1973 I solved the problem thanks
@paolozampini1973 said in problems with updating DUET WIFI 1.05+DUEX0.11:
What was the problem?
@phaedrux before I had made this type of setting because the two EXTRUDER are THE WIRES ARE CONNECTED E0 = DRIVER 3 and E1 = DRIVER 4 M584 X7 Y8 Z1:2 A5 B6 E0:1 S0 and the engines don't turn, they don't work to make it work I had to change the configuration leaving the wires connected E0 = DRIVER 3 and E1 = DRIVER 4 with this type of command M584 X7 Y8 Z1:2 A5 B6 E3:4 S0
and now they work well but I can't understand why they work these have come out that they are on the expansion card DUEX 0.11 CONFIGURED IN DUEX 2
E3 = DRIVER 6 AND AXIS B WORKS CONNECTED
E4 = DRIVER 7 IS DISABLED FOR EXTERNAL AXIS X
E5 = DRIVER 8 AND DISABLED FOR EXTERNAL AXIS Y
E6 = DRIVER 9 IS DISABLED NOT CONNECTED NO AXIS IS FREE
So how does it work and also works well?
then another question the cooling fins on the drivers I no longer have them installed Also because there are two 120mm fans if you remember I had problems with temperature error since I installed two 120mm fans I have not had any more problems
WHAT DO YOU THINK ABOUT IT?
Speaking of problems I have a problem with F7 no longer working the fan works I tested it on F8 and it works well but output 7 no longer works as never what advice can you give me?config (40).g
