Where I need to use this connector
  • undefined
    patel
    Any one can explain me. Where I can use red and black terminal inside my box. I have 3 white and 2 small (red and black), big 2 ( red and black
    • undefined
      Martin_S
      I had the same question once. Check out this thread, it might help.
      https://www.duet3d.com/forum/thread.php?id=2120
      If it ain't broke, fix it till it is =)
      • undefined
        whosrdaddy
        these are ferrules you need to use for power connection/heated bed and heater connections.
        Do not screw in the bare stranded as you will burn your power connectors.
        • undefined
          patel
          Thank for reply
          Can you explain how to update firmware. I am new use
          • undefined
            Do you mean the ferrules? They are for crimping on your wires before you put them in the terminal blocks. The small white ones are for the extruder heater wires. The larger red and black ones are for the power in connector and the bed heater connector.
            • undefined
              jacksat
              @patel:
              Thank for reply
              If you are new, then i strongly advice you to read the wiki
              a couple of times before you proceed.
              https://duet3d.com/wiki/Updating_main_firmware
              If you still don't undersand it ,then ask what the problem specific is and you will get help fast here.
              But you can't expect people will write down the whole procedure for you here on the forum,
              if it is nicely explained in the wiki.
              Please be more specific.
              1 out of 6
