    cannot connect to web control
    Duet Web Control
    web control wifi connection ipaddress
    • megamachineundefined
      megamachine
      I can no longer connect via duet web control
      "could not establish a connection to the duet firmware! Please check your settings and try again"
      is the error message I'm getting. Everything was working pretty much fine we changed wifi I put the new ssid and password using M587 it worked for a day then mid print I couldn't connect to the duets ip I tried M588 S"*" then used M587 to put the network in again it didn't work the first time did the same thing again and it worked this is what I get when I start it up and then run M587
      WiFi module started
      Connected
      WiFi module is connected to access point MYSSID IP address 192.168.5.##
      M587
      Remembered networks MYSSID IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
        I assume you are connected by USB and using a terminal software to send commands.
        What terminal software are you using?
        Can you send M122 and copy paste the results here?
        @megamachine said in cannot connect to web control:
        Where exactly are you seeing this message?
