BLTouch not detecting
  • undefined
    CrooKID
    Hello! some issues withthe bltouch not showing any detection. Correct setup in config.g:
    M558 P9 C"^zprobe.in" H5 F200 T6000
    propper deployment and retraction of the probes solonoid through:
    M950 S0 C"exp.heater3"
    The wiring is correct and has continuity. Just isnt showing once the tip is drawn back after touching the bed. Anything helps!!!
    undefined 1 Reply Last reply 5 Oct 2022, 06:36 Reply Quote 0
    • undefined
      Phaedrux Moderator @CrooKID
      @crookid said in BLTouch not detecting:
      What are you expecting to see? Where are you looking?
      If you do the static test described here, does it work to stop Z movement?
      https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
      undefined 1 Reply Last reply 5 Oct 2022, 15:39 Reply Quote 0
      • undefined
        CrooKID @Phaedrux
        @phaedrux
        In DWC; Dashboard; Status box; under Sensors; Z-Probe. The output of the probe does not change, ever. I can invert the signal by adding an "!" in front of the "^zprobe.in" and the signal will appear to have been inverted in the Z-Probe Status field. But really thats a superficial readout change. So, having run the static test and hoping that the Duet 2 WiFi board picked up the tip touching the bed is to no avail. This is the second BLTouch I've used/tested with. Swaped the Z-Probe and the GND signals too... nada.
        • undefined
          The probe status in DWC isn't updated fast enough to capture the very brief status change from the BLTouch since it resets immediately upon triggering.
          So you're saying that it doesn't trigger to stop the Z axis when sending a G30?
          In that case it sounds like your white signal wire is either not making a connection, or connected to the wrong place. Your config shows it should be on zprobe.in
          Please post your full config.g, homeall.g, homez.g.
          Also post the results of sending M122 and M98 P"config.g"
          undefined 1 Reply Last reply 26 Oct 2022, 20:27 Reply Quote 0
          • undefined
            CrooKID @Phaedrux
            @Phaedrux
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.3.13 on Sat Sep 24 2022 19:41:27 GMT-0600 (Mountain Daylight Time)
            G91 ; relative positioning
            G1 H1 X-242 Y-242 F6000 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-242 Y-242 F240 ; move slowly to X and Y axis endstops once more (second pass)
            G1 H1 Z-266.5 F240 ; move Z down stopping at the endstop
            G90 ; absolute positioning
            G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
            ; homez.g
            ; called to home the Z axis
            G1 H1 Z-266.5 F6000 ; move Z down until the endstop is triggered
            G92 Z-2.5 ; set Z position to axis minimum (you may want to adjust this)
              ; Configuration file for Duet WiFi (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.13 on Sat Sep 24 2022 19:41:26 GMT-0600 (Mountain Daylight Time)
            M550 P"Ender3" ; set printer name
            M918 P1 E4 F2000000 ; configure direct-connect display
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S0 ; physical drive 0 goes backwards
            M569 P3 S0 ; physical drive 3 goes backwards
            M569 P4 S1 ; physical drive 4 matches drive2
            M584 X0 Y1 Z2:4 E3 ; set drive mapping
            M671 X-27:263 Y115:115 S10 P2 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
            M92 X80.00 Y80.00 Z400.00 E130.00 ; set steps per mm
            M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X9000.00 Y9000.00 Z720.00 E6000.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X-5 Y-15 Z-3.5 S1 ; set axis minima
            M208 X235 Y235 Z250 S0 ; set axis maxima
            M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
            M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
            M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
            M558 P9 C"^zprobe.in" H5 F200 T6000 ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X-56.6 Y-3.5 Z2.5 ; set Z probe trigger value, offset and trigger height
            M557 X20:180 Y20:220 S40 ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
            M143 H0 S150 ; set temperature limit for heater 0 to 150C
            M308 S1 P"spi.cs1" Y"rtd-max31865" ; create sensor number 1 as a PT100 sensor in the first position on the Duet 2 daughterboard connector
            M307 H1 R2.383 K0.432:0.000 D17.52 E1.35 S1.00 B0 V23.8
            M143 H1 S375 ; set temperature limit for heater 1 to 275C
            M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
            ; Custom settings
            T0 ; select first tool
            • undefined
              Your homing files are set to use an endstop, not a probe.
              Replace those lines with something like
              G1 X150 Y150 F6000 ; move the center of bed
              G30 ; Probe the Z axis
