    Heater fault with no error when preheating extruder
    • ryanrocksforeverundefined
      ryanrocksforever
      I have a duet toolboard 1.2 brand new from matterhackers, thats connected to a 12v hemera running the high precision heater cartridge and a volcano hotend. Ever since I got the board it has not been able to heat up properly. On the last toolboard that I had everything worked fine until something on the board broke and caused the heater to be on all of the time. When preheating the extruder to 210 c the extruder gets up to about 40 c from 24 c ambient, and goes fault without any error message. when doing diagnostics before and after, no errors appear. I can incrementally heat up the hotend by increasing the heat target by 10-20c, but this is not ideal. When trying to tune the hotend using the autotune function, it reaches temperature fine, and after gives the error Auto tune of heater 1 failed due to bad curve fit (1.069 K=0.260:0.101 D=8.8) No matter what I do, deleting prexisting settings for the heatre or changing the temp target, it will not work.
      here is my config.g
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Jan 30 2022 08:57:25 GMT-0800 (Pacific Standard Time)
      G90                                                       ; send absolute coordinates...
      M83                                                       ; ...but relative extruder moves
      ;M550 P"RyansPrinter"                                     ; set printer name
      M669 K1                                                   ; select CoreXY mode
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      ;M552 S1                                                   ; enable network
      M586 P0 S1                                                ; enable HTTP
      M586 P1 S0                                                ; disable FTP
      M586 P2 S0                                                ; disable Telnet
      M569 P0.0 S1                                              ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                            ; physical drive 0.1 goes forwards
      M569 P0.2 S1                                              ; physical drive 0.2 goes forwards
      M569 P0.3 S1                                              ; physical drive 0.3 goes forwards
      M569 P0.4 S1                                            ; physical drive 0.4 goes forwards
      M569 P0.5 S1 T0:2:0:0                                           ; physical drive 0.4 goes forwards same
      M569 P0.6 S1 T0:2:0:0                                           ; physical drive 0.4 goes forwards Odrive recoomendeded timing
      M569 P121.0 S0                                            ; physical drive 0.4 goes forwards
      M584 X0.6 Y0.5 Z0.2:0.4:0.1 E121.0                                  ; set drive mapping 3 z motors
      ;M584 X0 Y1  E4; three Z motors connected to driver outputs 2, 5 and 6
      M671 X510:-10:510 Y450:250:50 S4 ; leadscrews at rear right, left middle and front right
      M350 X16 Y16 Z16 E16 I1                                   ; configure microstepping with interpolation remove X16 Y16
      M92 X105.57 Y105.57 Z1200 E409.00                        ; set steps per mm
      M566 X1800.00 Y1800.00 Z60.00 E120.00                       ; set maximum instantaneous speed changes (mm/min)
      M203 X75000 Y75000 Z180.00 E1200.00                   ; set maximum speeds (mm/min)
      M201 X12000 Y12000 Z20.00 E250.00                       ; set accelerations (mm/s^2)
      M906 X800 Y800 Z1500 E800 I30                              ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                   ; Set idle timeout
      M208 X0 Y0 Z0 S1                                          ; set axis minima
      M208 X470 Y480 Z500 S0                                    ; set axis maxima
      M574 X1 S1 P"io1.in"                                      ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in
      M574 Y2 S1 P"!io0.in"                                      ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in
      M574 Z1 S2                                                ; configure Z-probe endstop for low end on Z
      ;M558 P8 C"^121.io0.in" H10 F120 T6000                      ; set Z probe type to switch and the dive height + speeds
      ;G31 P500 X0 Y0 Z0.95                                       ; set Z probe trigger value, offset and trigger height
      M557 X15:470 Y15:480 S40                                  ; define mesh grid
      M558 P8 C"121.io2.in"  H3 F1000 T6000 A20 S0.005 ; PINDA set Z probe type to switch and the dive height + speeds
      ;M308 S2 P"121.temp1" A"PINDA" Y"thermistor" T100000 B3950
      G31 P500 X5 Y-3 Z1                                   ; set Z probe trigger value, offset and trigger height
      ;M557 X20:485 Y41:360 P7                             ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138              ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                        ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 R0.210 C247.5 D2.42 S1.00 V12.1
      ;M307 H0 B1 S1.00                                          ; enable bang-bang mode for the bed heater and set PWM limit
      ;M307 H0 S1.00 A350 R2.429 C140 D5.5 B1 ; 2-19-22 auto tuning params using bang- BANG mode
      ;Heater 0 model: heating rate 2.429, cooling time constant 140.0, dead time 5.50, max PWM 1.00, calibration voltage 0.0, mode bang-bang
      M140 H0                                                   ; map heated bed to heater 0
      M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
      M950 H1 C"121.out0" T1                                    ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 R1.069 K0.260:0.101 D8.8 E1.35 S1.00 B0 V12.4 ; R=1.069 K=0.260:0.101 D=8.8
      M143 H1 S280                                              ; set temperature limit for heater 1 to 280C
      M950 F0 C"out5" Q500                                      ; create fan 0 on pin out3 and set its frequency
      M106 P0 S0 H-1 C"Board Fan"                                            ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"121.out1" Q250                         ; create cooling fan 1 on pin toolboard out1 and set its frequency
      M106 P1 S0 H-1 B1 C"Part Cooling Fan"            ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"121.out2" Q500                                  ; create fan 2 on pin 121.out1 and set its frequency
      M106 P2 S1 H1 T45                                         ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F1                                          ; define tool 0
      G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
      G10 P0 R0 S0                                              ; set initial tool 0 active and standby temperatures to 0C
      ; Custom setting s are not defined
      M955 P121.0 I54 ; specify orientation of accelerometer on Toolboard 1LC with CAN address 121
      M593 P"zvd" F27.2 ; use ZVD input shaping to cancel ringing at 40.5Hz
        What command are you using to tune the hotend?
        ryanrocksforeverundefined 1 Reply Last reply Reply Quote 0
          ryanrocksforever @Phaedrux
          @phaedrux I am using M303 T0 S220 P1 F0.5 A23 I have tried different variations with the S parameter, and with the PWM, if I set the Pwm to 0.75 or any number other than 1 the tuning will get stuck and just fail.
            Can you show a photo of your hotend? Is the part cooling fan blowing on the block? Do you have a silicone nozzle sock?
              @Phaedrux I have a silicone sock on the nozzle, it is a hemera, with the volcano and an e3d high precision heater cartridge. I have two cooling fans wich are just 5010 blowers, which i tired turning down for the tuning but it did not do anything. I ordered a new heater cartridge, so that may fix this, otherwise it is probably a faulty toolboard which i will need to get replaced
