    Bl touch issue
    • joehsmashundefined
      joehsmash
      The weirdest thing and I'm not entirely sure when this started however it seems that sometimes the machine has problems deploying the pin, ill go through 10 prints like normal, and everything is working perfect. than it will have trouble deploying the pin. it just sits there and flashes.
      i can reset it just fine, some times I can self test it and it works flawless. other times it will make it 2-6 times on self test before it starts flashing and cant deploy the pin.
      think I have a bad BL? or is it just a firmware issue?
      Norderundefined 1 Reply Last reply Reply Quote 0
      • Norderundefined
        Norder @joehsmash
        @joehsmash
        A bent pin is often to blame if the BLTouch sticks.
        You can unscrew the BLTouch at the top, there is a grub screw in there. Remove these and you can take the pin out of the top of the BLTouch.
        I left the opening blank on mine so I don't have to remove the BLTouch from the printhead.
        I can remove the grub screw and then take a magnet that pulls the pin up and I can remove it.
        But you can also put the Allen key in the opening after removing the grub screw. The pin has a small magnet at the top end which then gets stuck on the Allen key.
        When the pin is removed, you can better see in which direction it is bent.
        It should be carefully heated (pin made of plastic) before bending it back.
        It can quickly happen that the BLTouch hits any part of the printer with the pin extended and the pin bends.
        Of course you can extend the pin and if necessary you can see in which direction the pin is bent without having to remove the pin.
        If there are still problems with the pin getting stuck even after you have straightened the pin, it may help to sand the pin smooth with very fine wet sandpaper.
        I would advise against oil because oil can increase the problem because it sticks the pin to the inside of the BLTouch housing or the oil is too aggressive and softens the plastic.
        P.S.:
        The BLTouch must be installed very straight, it should not be tilted to any side, mounted on the print head.
        Otherwise it can also lead to the pin having problems falling down under its own weight because it rests on the side of its guide and friction occurs.
        Google Translate
        -- Original Text --
        Sehr oft ist ein verbogener Pin daran schuld wenn der BLTouch mal klemmt.
        Du kannst den BLTouch oben aufschrauben, dort ist eine Madenschraube drin. Entferne diese und Du kannst den Pin oben aus dem BLTouch heraus nehmen.
        Ich habe die Öffnung bei mir frei gelassen, so dass ich den BLTouch nicht vom Druckkopf entfernen muss.
        Ich kann die Madenschraube entfernen und nehme dann einen Magneten der den Pin nach oben zieht und ich ihn entnehmen kann.
        Man kann aber auch den Inbusschlüssel in die Öffnung stecken nachdem man die Madenschraube entfernt hat. Der Pin hat am oberen Ende einen kleinen Magneten der dann am Inbusschlüssel hängen bleibt.
        Wenn der Pin ausgebaut ist kann man besser erkennen in welche Richtung er verbogen ist.
        Man sollte ihn vorsichtig erwärmen (Pin aus Kunststoff) bevor man ihn zurück biegt.
        Es kann schnell mal passieren dass der BLTouch mit ausgefahrenem Pin an irgendeiner Stelle des Druckers anschlägt und sich der Pin verbiegt.
        Du kannst natürlich den Pin ausfahren und ggf erkennst Du, ohne den Pin ausbauen zu müssen, in welche Richtung der Pin verbogen ist.
        Sollte es selbst nach dem gerade biegen des Pins noch Probleme geben das sich der Pin verklemmt, dann hilft eventuell ein glattschleifen des Pins mit sehr feinem Nassschleifpapier.
        Von Öl würde ich abraten da Öl das Problem erhöhen kann, weil es den Pin an das innere des BLTouch Gehäuses klebt oder das Öl zu aggressiv ist und den Kunststoff weich werden lässt.
        P.S.:
        Der BLTouch muss sehr gerade eingebaut sein, er sollte nicht zu irgendeiner Seite gekippt, am Druckkopf montiert sein.
        Sonst kann es auch dazu führen das der Pin Probleme hat durch sein eigenes Gewicht nach unten zu fallen weil er seitlich an seiner Führung anliegt und es zu Reibung kommt.
        DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
        Thingiverse
