    Extract temp to external display
    Duet Web Control
    1.6k
    • tecnoundefined
      tecno
      Hi guys,
      Is there an easy way to get hotend/bed/chamber temperatures on external display like 4x20 text?
        dc42 administrators @tecno
        @tecno you will need a microcontroller (e.g. Arduino or RPi Pico) to drive the 4x20 display. If it's network enabled then it can use the rr_model http call to retrieve the temperature from the object model. Alternatively, if your Duet has a spare serial port then you can connect your microcontroller to that port and use the M409 command to retrieve the temperature from the object model.
        Depending on which Duet you are using, it may be simpler to add a 12864 graphics display, which some Duets can drive directly, and construct a menu file that displays just the temperature.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @dc42
          Using Mini5 for the printer in question so 12864 might be a easier solution.
          My other printers rr_model http call.
            @tecno I suggest you read https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_12864#duet-3-mini-5-support-for-12864-displays then.
            • tecnoundefined
              tecno @dc42
              So this would be OK to use? MKS Mini12864 V3
                @tecno yes that display is suitable.
                • tecnoundefined
                  tecno @dc42
                  So I got two displays now to play with, need help to what files to copy to SD card and config lines.
                  1 Bigtree-tech MINI12864 V.1.0
                  2. Bigtree-tech RepRapDiscount full graphic smart controller
                  Advice much appreciated
                  DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                  • DIY-O-Sphereundefined
                    DIY-O-Sphere @tecno
                    @tecno said in Extract temp to external display:
                    12864
                    The second one may have problems with the logic level.
                    Background info here
                    https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Connecting_a_12864_mono_graphics_LCD_display_with_rotary_encoder
                    The second one works for me with a level shifter
                    https://forum.duet3d.com/topic/23034/12864-display-st7920-on-duet-3-mini5
                    But I would recommend to use the first one.
                    Then
                    M918 P2
                    must be set in config.g
                    For the menu files see here:
                    https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_12864_menu
                    I use this version
                    https://github.com/jadonmmiller/UltimateDuetMenuSystem
                    There is also a demo video.
                    You can download the archive here:
                    https://github.com/jadonmmiller/UltimateDuetMenuSystem/releases/download/V1.10/V1.10_UltimateDuetMenuSystem.zip
                    Extract the files and upload them via DWC to the display folder.
                    https://docs.duet3d.com/en/User_manual/Reference/Duet_Web_Control_Manual#main-menu
                    (UTC+1)
                    • tecnoundefined
                      tecno @DIY-O-Sphere
                      @DIY-O-Sphere
                      This is what I have in config
                      M575 P1 S0 B57600 ; enable support for PanelDue
                      M918 P2 ; configure direct-connect display
                      M550 P"BigDelta"
                      So how do I create DISPLAY and copy the files there?
                      DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
                        DIY-O-Sphere @tecno
                        @tecno
                        Sorry,
                        DWC link is outdated.....I haven't found the upload in the current version.....
                        Pull the SD card and create an folder called "menu"
                        (UTC+1)
                          DIY-O-Sphere @tecno
                          @tecno
                          In DWC it is here:
                          (UTC+1)
                          • tecnoundefined
                            tecno @DIY-O-Sphere
                            @DIY-O-Sphere
                            I have menu and creates Display folder and files in it. Still no go
                            • tecnoundefined
                              tecno @tecno
                              But does not show in left column ?
                                DIY-O-Sphere @tecno
                                @tecno
                                Put all menu files directy into menu folder. You don't need the subfolder display.
                                (UTC+1)
                                • tecnoundefined
                                  tecno @DIY-O-Sphere
                                  @DIY-O-Sphere
                                  Done and still no go. Is M918 P2 enough to initialize the display?
                                    DIY-O-Sphere @tecno
                                    @tecno
                                    https://docs.duet3d.com/User_manual/Reference/Gcodes#m918-configure-direct-connect-display
                                    Maybe check the contrast parameter
                                    That is different to mine.....
                                    (UTC+1)
                                    • tecnoundefined
                                      tecno @DIY-O-Sphere
                                      @DIY-O-Sphere
                                      M918 P2 E4 R6
                                      Done no diff, but when I turn the encoder board resets.
                                      tecnoundefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
                                      • tecnoundefined
                                        tecno @tecno
                                        Tried another set of cables = no go
                                        Is it maybe so that there is no firmware, if so what files do I need?
                                          DIY-O-Sphere @tecno
                                          @tecno
                                          Maybe swapped wiring?
                                          Check if EXP1 + EXP2 on board and the display are plugged in correctly.
                                          (UTC+1)
                                            DIY-O-Sphere @tecno
                                            @tecno
                                            This is what it looks like in my menu folder
                                            (UTC+1)
