Power outage capacitors
  • Hi,
    Maybe there s someone here that has some experience with this. I have set today the power outage protection as the documentation describes but it does not have any effect. So, how many uF should i install to the output of my power supply to run a small gcode of lifting the Z.
    Thanks!
    DuetWifi 1.19, powered at 24V.
    The power outage protection works faster in firmware 1.20beta4 so I suggest you upgrade to that version first. Read the upgrade notes, in particular the parameters to the M911 command have changed.
