Configuring RT1000
My setup is:
Duet 3
Duet tool board
RPI 4B
Firmware updated to RRF3.4.2I just purchased a Slice Engineering RTD PT1000 thermistor. My thermistor config is:
M308 S0 P"0.temp0" Y"thermistor" A"Bed" T100000 B4725 C0.0000000706 M308 S1 P"20.temp0" Y"thermistor" A"Hotend" T100000 B3950
My hot end temp is showing 179.9c where my bed is showing 23.9c. I've tried B4725 and B3950. What should the configuration be for?
@dhusolo configure it as a PT1000 not a thermistor. See here https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m308-set-or-report-sensor-parameters
@jay_s_uk Go figure I completely forgot to change that. That worked thanks.
