    Duet shows different temps
    • NOVAprintundefined
      NOVAprint
      This is a different presentation of a previous problem. I have an E3d Thermistor and this is my printer with a Semitec 104GT thermistors this is my configuration
      M308 S1 P"e0temp" Y"thermistor" T1000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      I het a reading of -50.8 for the temp with low voltage and I get a heater fault -273 when I turn on the power switch. I am using a smart effector and am using the two middle plugs to get the temp for T0. I redid the wiring there are not likely any wiring issues, however it does seem that after I bumped the smart effector the temps started registering wonky, full dislosure. The run for the wiring is long too, I am not sure how much that matters it is about 1.5 meters.
        droftarts administrators @NOVAprint
        @NOVAprint said in Duet shows different temps:
        T1000? Should be T100000.
        NOVAprintundefined 1 Reply Last reply Reply Quote 1
          NOVAprint @droftarts
          @droftarts
          T100 worked on USB power ,my duet 2 is around five years old: how much of a factor is that?
          Here is my config.g with the correct T value.
          M308 S1 P"e0temp" Y"thermistor" T1000000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
          My M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2022-10-05 09:01:07
            dc42 administrators @NOVAprint
            @NOVAprint that's also wrong, you've used T1000000 instead of T100000 (one zero too many).
