    File Updates lost after Reboot
    Duet Web Control
    • tmreithundefined
      tmreith
      After updating system files and or adding new gcode files, the system recognizes the changes or additions. However, after rebooting the system, the file system reverts to an older date. Note, I have 4 machines with the identical setup, but I am only seeing this behavior on the one machine. Possible file corruption???
      Currently running:
      Board: Duet 3 MB6HC (MB6HC)
      DSF Version: 3.3.0
      Firmware: RepRapFirmware for Duet 3 MB6HC 3.3 (2021-06-15)
      T3P3Tonyundefined Phaedruxundefined gloomyandyundefined chrishammundefined 4 Replies Last reply Reply Quote 0
      • T3P3Tonyundefined
        T3P3Tony administrators @tmreith
        @tmreith given this is running in SBC mode maybe @chrishamm has some troubleshooting steps.
        www.duet3d.com
        tmreithundefined 1 Reply Last reply Reply Quote 0
        • tmreithundefined
          tmreith @T3P3Tony
          @T3P3Tony Yes, running SBC
            Phaedrux Moderator @tmreith
            @tmreith said in File Updates lost after Reboot:
            DSF Version: 3.3.0
            Update firmware? I believe there were some fixes recently on file saving.
            • gloomyandyundefined
              gloomyandy @tmreith
              @tmreith What are you doing to "reboot the system"?
              • chrishammundefined
                chrishamm administrators @tmreith
                @tmreith Possibly damaged microSD card? Try exchanging it, ideally with an A1- or A2-rated microSD card.
                Duet software engineer
                • tmreithundefined
                  tmreith @chrishamm
                  @chrishamm Yes, microSD card damaged and was in forced ready-only mode. I replaced with a new microSD A1 and back to normal. Thanks!
