DWC unavailable after update to 3.4.3
Duet 2 wifi
was on 3.3, with wifi server 1.26 and DWC 3.3.0updated by uploading Duet2and3Firmware-3.4.3.zip in DWC, let it upload, pressed yes to update firmware, and after it uploaded, updated, and rebooted it no longer can connect.
Through paneldue i can see its upgraded to 3.4.3
it connects to wifi and gives me an ip address, i can ping the ip address.
i cannot access DWC via name.local or via IP address.
I have removed SD card, deleted www folder and replaced with the contents of DuetWebControl-SD.zipStill cannot connect to DWC on multiple bowsers tried.
Any suggestions ?
What error do you get in your browser when you try to reach it?
What does M122 report? Does the wifi firmware show 1.27?
Have you done a hard page refresh in the browser?
@Jarery it may be connected to this. https://forum.duet3d.com/topic/30067/loss-remote-access-to-duet2-wifi-after-firmware-3-4-3-upgrade?_=1665828409475
Try the binary in that topic -
M122 shows the firmware is 3.4.3 but does not show the wifi version. I only have paneldue to connect and it doesnt seem to show all the info
That was it !
Thanks for pointing me to it. -
