    Can't get DWC to show up in browser
    Duet Web Control
    • mrehorstdmdundefined
      mrehorstdmd
      Duet2 WiFi board, connect with YAT via USB, firmware version reported is 3.3, shows wifi module active and connected to my network with IP address 192.168.0.176. The blue light on the wifi module is on. All the same before and after board and router reboots.
      I check router- it shows the connection to the Duet board at 192.168.0.176. I reboot router- reconnects at same IP address.
      I go to web browser and enter 192.168.0.176 and it says "site can't be reached, took too long to respond"
      I try to ping 192.168.0.176 and all requests time out.
      Config file:
      M550 P"Arrakis" ; set device name
      M669 K1 ; select CoreXY mode
      M551 P"dune" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P5 S1 R0 T4.0:5.0:6.0:12.0 ; drive 5 reverse, lo enable, timing parameters for servomotors
      M569 P6 S1 R0 T4.0:5.0:6.0:12.0 ; drive 6 reverse, lo enable, timing parameters for servomotors
      M584 X5 Y6 ; set drive mapping- X at drive 5, Y at drive 6
      M350 X1 Y1 ; configure microstepping without interpolation
      M92 X31.25 Y31.25 ; set steps per mm
      M566 X3000.00 Y3000.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X96000.00 Y96000.00 ; set maximum speeds (mm/min)
      M201 X10000.00 Y10000.00 ; set accelerations (mm/s^2)
      M84 S3 ; Set idle timeout
      M208 X590 Y980 S0 ; set axis maxima
      M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin zstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z0
      ; macro to run at power up- wifi will not work until this file is finished
      ; M98 P/macros/BVGN22
      Any suggestions?
      Thanks!
        What does M122 say about the wifi module?
        Can you try setting up the Duet in access point mode to see if the module itself is still working correctly?
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
        mrehorstdmdundefined 1 Reply Last reply Reply Quote 0
          mrehorstdmd @Phaedrux
          @Phaedrux Here's the M122 result from YAT:
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
          Board ID: 0JD0M-9P6B2-NJ4S8-6JTD2-3S86P-KA7LL
          Used output buffers: 1 of 24 (1 max)
          Static ram: 23876
          Dynamic ram: 73860 of which 28 recycled
          Never used RAM 16652, free system stack 164 words
          Tasks: NETWORK(ready,13.3%,417) HEAT(delaying,0.0%,386) Move(notifyWait,0.1%,364) MAIN(running,86.6%,519) IDLE(ready,0.1%,29), total 100.0%
          Owned mutexes: USB(MAIN)
          Last reset 00:22:41 ago, cause: power up
          Last software reset at 2022-07-21 23:28, reason: User, GCodes spinning, available RAM 13620, slot 1
          Error status: 0x00
          Step timer max interval 0
          MCU temperature: min 17.5, current 26.6, max 27.2
          Supply voltage: min 0.2, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Slowest loop: 3.41ms; fastest: 0.12ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 2.1ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is ready with "M122" in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.55ms; fastest: 0.00ms
          HTTP sessions: 0 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.26
            WiFi MAC address f4:cf:a2:e3:14:57
            WiFi Vcc 3.35, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 24616
            WiFi IP address 192.168.0.176
            WiFi signal strength -53dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
          I'll try access point setup...
            Could also try a fresh SD card.
              @Phaedrux
                mrehorstdmd @mrehorstdmd
                I just tried backing up the card and it's taking forever to read it. Maybe that's the problem...
                It's getting late- I'll try again tomorrow morning.
                Thanks!
                mrehorstdmdundefined 1 Reply Last reply Reply Quote 1
                  I went through 3 cards before I found one that was working right. That fixed it. Thanks!
