Solved Duet 3D MB 6HC can't connect (status LED dim)
Raspberry pi can't connect to Duet 3D mainboard 6HC. When plugged into a different Duet board, the pi has no issue connecting and runs as normal. Tried different pi, power supply, and even trying to connect to a pc. When connected to power the status LED doesn't blink like normal but is dim and constant. Any suggestions?
@bastacy That is the situation if the firmware on the board has been erase. Please try and follow this fallback procedure to use BOSSA to re-install the firmware:
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
@T3P3Tony Thank you very much! That worked!
undefined T3P3Tony marked this topic as a question
undefined T3P3Tony has marked this topic as solved
