Connect a Z probe to duet 2 wifi.
OMRON TL-Q5MC2-Z INDUCTIVE SWITCH PROBE - NPN - NC - 5MM
Ho do I connect this to my Duet 2 wifi.
@Karim
Here's a link to the documentation...
[https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting] -
@cosmowave ok I found this.
Hey need help setting up my probe, I want to use the Z end stop. I want it to home xy and z and then level the gantry. I have 4 z motor. As of now xyz homing work.
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Oct 14 2022 18:23:20 GMT-0400 (Eastern Daylight Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Voron" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; --- Z Drive map --- ; _______ ; | 6 | 7 | ; | ----- | ; | 5 | 8 | ; ------- ; front ; ; (looking at the printer from the top) ; Drive directions M569 P0 S1 ; A M569 P1 S1 ; B M569 P3 S0 ; Extruder M569 P5 S0 ; Z1 M569 P6 S1 ; Z2 M569 P7 S0 ; Z3 M569 P8 S1 ; Z4 M584 X0 Y1 Z5:6:7:8 E3 ; Motor mapping and steps per mm M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E562.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X60000.00 Y60000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min) M201 X6000.00 Y6000.00 Z4000.00 E250.00 ; set accelerations (mm/s^2) ; Drive currents M906 X1500 Y1500 Z1200 E400 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S10 ; Set idle timeout ; Axis Limits M208 X0 Y10 Z0 S1 ; set axis minima M208 X350 Y350 Z350 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:330 Y15:330 S20 ; define mesh grid ;Bed (Keenovo 750w 120v) M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 R0.490 K0.247:0.000 D1.97 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ;E3d Revo Voron) M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 R4.091 K0.614:0.000 D1.92 E1.35 S1.00 B0 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"duex.fan3" Q300 ; create fan 2 on pin duex.fan3 and set its frequency M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on M950 F3 C"duex.fan4" Q300 ; create fan 3 on pin duex.fan4 and set its frequency M106 P3 S1 H1 T45 ; set fan 3 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss ; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Oct 21 2022 08:34:22 GMT-0400 (Eastern Daylight Time) M561 ; clear any bed transform G29 ; probe the bed and enable compensation -
@Karim Have you seen that?
https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_auto_levelling -
@cosmowave Hey I did read but still confuse. I found this.
; Bed leveling M671 X-65:-65:365:365 Y0:395:395:0 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right) M557 X25:275 Y25:275 S25 ; Define bed mesh grid (inductive probe, positions include the Y offset!) ; Z probes M558 K0 P8 C"^zprobe.in" T18000 F120 H5 A5 S0.01 R0.2 G31 K0 P500 X0 Y25 Z2.0 ; Don't really care about inductive probe Z offset M558 K1 P8 C"^zstop" T18000 F60 H2 A10 S0.005 R0.2 G31 K1 P500 X0 Y0 Z0.32 ; Z switch offset (if positive, greater value = lower nozzle. if negative, more negative = higher nozzle) ; bed.g ; Called to align the gantry to the bed plane via G32 ; Clear any bed transform M561 ; Turn off noisy Extruder motor M84 E ; Home all axes G28 G30 K0 P0 X250 Y250 Z-99999 G30 K0 P1 X250 Y50 Z-99999 G30 K0 P2 X50 Y50 Z-99999 G30 K0 P3 X50 Y250 Z-99999 S4 -
@Karim I can't help much more, because i don't have experience with leadscrews for ABL.
Have you seen this?
https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling
It has instructions and examples on how to setup leveling.
@Phaedrux thanks guys.
