    M98 P"0:/macros/Level Gantry"
    • Karimundefined
      Karim
      Error: in file macro line 8 column 6: M84: expected number after 'E'
      G32
      G28 Z
      M98 P"/macros/print_scripts/goto_bed_center.g"
      G1 X140 Y150 F6000
        You'd have to actually share the macro being called for us to see what's going on, but from the error message it would appear you have M84 with an E but no number after it. On line 8, column 6.
        It could be in bed.g (G32) or homez.g (G28 Z) or "/macros/print_scripts/goto_bed_center.g"
        Karimundefined 1 Reply Last reply Reply Quote 0
        • Karimundefined
          Karim @Phaedrux
          @Phaedrux ok here.
          ;Level Gantry
          G32
          G28 Z
          ;goto_bed_center.g
          G1 X140 Y150 F6000
          don't know is it's in .bed
          ; bed.g
          ; Called to align the gantry to the bed plane via G32
          ; Clear any bed transform
          M561
          ; Turn off noisy Extruder motor
          M84 E
          ; Home all axes
          G28
          ; Lower currents, speed & accel
          M98 P"/macros/print_scripts/speed_probing.g"
          M98 P"/macros/print_scripts/z_current_low.g"
          M98 P"/macros/print_scripts/xy_current_low.g"
          ; Probe the bed at 4 points, x3 for more precision
          M558 K0 H10 F1200 ; increase the depth range, gets the gantry mostly level immediately
          M98 P"/sys/bed_probe_points.g"
          M558 K0 H4 F240   ; reduce depth range, probe slower for better repeatability
          M558 K0 H1 F60    ; reduce depth range, probe slower for better repeatability
          ; Restore high currents, speed & accel
          M98 P"/macros/print_scripts/speed_printing.g"
          M98 P"/macros/print_scripts/xy_current_high.g"
          M98 P"/macros/print_scripts/z_current_high.g"
            https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m84-stop-idle-hold
            M84 E needs a number after E to tell it which extruder. If you only have one, it would be E0
            • Karimundefined
              Karim @Phaedrux
              @Phaedrux thanks that work.
              • dc42undefined dc42 marked this topic as a question
