    Inductive sensor failing
    • Tinchusundefined
      Tinchus
      This post is deleted!
        Can you share more info on your setup and config?
        If it worked reliably before updating firmware can you try reverting to an older firmware to verify?
        How did you check the probe and wiring?
        Tinchusundefined 1 Reply Last reply Reply Quote 0
        • Tinchusundefined
          Tinchus @Phaedrux
          @Phaedrux I found the problem: the temperature was expanding the probe casing, and the probe was somehow "faulty" (not really, the problem was n the cable, despite it was not broken, my homing routing was hitting the cable base and that must have loosen something in the conection with the electroncs, and that problem only showed when everything was really hot). Also this was triggered because of the histeresis of the probe, the faulty connection caused by the temperature expansion together with the histeresis, made the probe to sense and then stay on the triggered state)
