    Question About the UI: Scrollbar Gone from G-code List
    Documentation
    372
    • gbartschundefined
      gbartsch
      The scrollbar has been removed from the g-code listing and scrolling the list requires using the mouse scroll wheel. Because of my disability I cannot easily use the scroll wheel so moving up and down the list is very difficult.
      Would someone be able to put the scrollbar back?
      Custom cartesian dinosaur machine; it's a tank but just works so I just keep tweaking it. / Duet Ethernet 1.02 or later / RepRapFirmware for Duet 2 WiFi/Ethernet: 3.4.5 / SuperSlicer
      • dc42undefined dc42 moved this topic from Documentation
        You mean here? https://docs.duet3d.com/en/User_manual/Reference/Gcodes
        What browser/version are you using?
        I still see a scroll bar on Chrome, but the touch point is very small because of the long length of the page.
        gbartschundefined 1 Reply Last reply Reply Quote 0
        • gbartschundefined
          gbartsch @Phaedrux
          @Phaedrux Thank you. I use Vivaldi (uses Chrome engine) but even using Chrome I can't see any scrollbar when I mouse over the g-code pane like I do when I mouse over the main pane on the far left. I use W10.
          Norderundefined 1 Reply Last reply Reply Quote 0
            Ah I see what you mean. One for @T3P3Tony
            • Norderundefined
              Norder @gbartsch
              @gbartsch
              If you are having trouble turning the mouse wheel because of your physical limitations, try clicking the mouse wheel. This changes the cursor to a circle with up and down directional arrows. Now all you have to do is move the mouse up or down and the website or section of a website will move continuously without having to hold down any mouse button.
              DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
              Thingiverse
              gbartschundefined 1 Reply Last reply Reply Quote 1
              • gbartschundefined
                gbartsch @Norder
                @Norder Thank you for the suggestion. Because I accidentally would click the scroll wheel I covered it so I cannot click it. I'd take a picture of my mouse and how I use it but it's filthy and beaten up after years of use and subsequent additional modifications. The simplest solution for all - and one that would not inconvenience anyone because the two scrolling methods could work together - is to put scrollbars back. I hope the devs can do that.
                • gbartschundefined
                  gbartsch @Phaedrux
                  @Phaedrux Thank you Sir 🙂
                    If you click within the side bar area you can then use the spacebar to shift the list downwards and shift-spacebar to shift it upwards a page at a time.
                    • dc42undefined dc42 moved this topic from Duet Web Control
                    • Norderundefined
                      Norder @Phaedrux
                      And with the keyboard arrow keys 🔼🔽 you can generally move up and down the entire website line by line.
                      If you click with the normal mouse pointer (arrow) in the area of the website where the scroll bar is missing, then you only move this area with the arrow keys on the keyboard.
                      Thingiverse
                      • gbartschundefined
                        gbartsch @Norder
                        @Norder Oh thank you! This is very good and even easier than picking a scrollbar (if one existed). Because normally I click a scrollbar before using arrow keys I didn't even think to try this because said scrollbar didn't exist. Your suggestion is quite perfect - thank you again. 😃
                        • droftartsundefined droftarts marked this topic as a question
                        • droftartsundefined droftarts has marked this topic as solved
