    Fysetc Paneldue 5i not displaying SD card contents
    • Larry3Dundefined
      Larry3D
      Hello, I currently have a Fysetc panel due 5i clone connected to a Duet 3 Mini 5+ that will not display the contents of the SD card on the screen when inserted, however I am able to see the contents of the SD card through the web interface so I know that the SD card is working. Could this be an issue with the panel due firmware or SD card file format? Thanks
        Are all firmwares up to date?
        Larry3Dundefined 1 Reply Last reply Reply Quote 0
        • Larry3Dundefined
          Larry3D @Phaedrux
          @Phaedrux Yes, I am currently setting up the board for my Prusa MK2.5s and have updated the firmware on the panel due 5i and Mini 5+ board to the latest version. Also, the board is connected using the 10 pin ribbon cable
            dc42 administrators @Larry3D
            @Larry3D does the SD card selection icon appear on PanelDue? If so, what happens when you touch it to select the second slot?
            • Larry3Dundefined
              Larry3D @dc42
              @dc42 Apologies for the late reply, I found that the firmware I loaded onto the panel due was not the correct one, upon erasing the panel due and loading the correct version of the firmware, the SD card is now displaying the contents. Therefore my issue has been resolved, thank you.
              • dc42undefined dc42 marked this topic as a question
