[3.4.1] Custom mCodes not supported in Console
We are now extensively using DSF-Python for custom mCodes. However, they are unavailable through the PanelDue's Console. A warning stating "Command is not supported" is returned.
Is this something that can be expanded for it to handle?
@oozeBot question for @chrishamm about how gcode commands get passed back from other inputs like Serial back to DSF.
@oozeBot Thanks for pointing this out, I'll add a fix to RRF. To work-around this limtiation for now, you should be able to create custom macro files for your M-codes and to wrap the M-code again from there.
Example for
M1010 S"foobar"
:M1010.g:
M1010 S{param.S}
@T3P3Tony @chrishamm - Weirdly, we hijacked M587 through DSF-Python for some additional functionality and it is working through the console.. but nothing else is.
Unfortunately, what we need won't work as a macro as it requires user input, but as long as it can be fixed in an upcoming release, we should be in good shape. Thanks!
@oozeBot File-dependent M-codes are already sent back to DSF because DSF needs to handle or intercept them:
// Pass file- and system-related commands to the SBC service if they came from somewhere else. // They will be passed back to us via a binary buffer or separate SPI message if necessary. if ( reprap.UsingSbcInterface() && reprap.GetSbcInterface().IsConnected() && !gb.IsBinary() && ( code == 0 || code == 1 || code == 20 || code == 21 || code == 22 || code == 23 || code == 24 || code == 26 || code == 27 || code == 28 || code == 30 || code == 32 || code == 36 || code == 37 || code == 38 || code == 39 || code == 112 || code == 470 || code == 471 || code == 503 || code == 505 || code == 540 || code == 550 || code == 552 || code == 586 || (code >= 587 && code <= 589) || code == 703 || code == 905 || code == 929 || code == 997 || code == 999 ) ) { gb.SendToSbc(); return false; }
I've just added some new code that makes sure unknown G/M-codes are sent back to DSF before the default action is attempted (i.e. execute
Mxxx.g
or report an error if that fails).
