    Mixing voltages on the smart effector
    • KeepGettingTextsundefined
      KeepGettingTexts
      I have a 24V system. However, I installed a small 1A 12V power supply for my hotend fan which used a 40mm Noctua. I installed the stock 30mm E3D fan and would eventually like to go back to the much quieter Noctua. I assume that the effector is powering the LED's from the hotend fan supply since that would be the only voltage that is constantly present.
      My question is that I was wondering if it is possible to use 12V to supply just the hotend fan while leaving the heater and part fans at 24V? Would I need to install the jumper for 12V supply if I did, and would it harm anything if I have mixed voltages like that?
        Yes that should work. The hot end fan + illumination LED circuit is separate from the print cooling fan and heater circuits.
